2005 V70 2.5t AWD ticking/rattling Topic is solved
- RickHaleParker
- Been thanked: 978 times
Sounds to me like it changed pitch when the transmission shifted ... Exhaust leak.
Active
Past
Past
It quiets down a lot after warming up. Also don't hear it in reverse.
Definitely gonna have them check driveshaft, axles, Angle gear. I'm really curious to find out where it's coming from.
I looked up what an exhaust leak is, however, the turbo seems to be in decent shape. No weird smells coming from the engine or climate vents
- RickHaleParker
Exhaust manifold heats and expands sealing the leak.
Exhaust manifold gasket or a loose Exhaust manifold bolt.
Active
Past
Past
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
The noise is speed-sensitive, not RPM. Something is loose in the drivetrain AFTER transmission.RickHaleParker wrote: 10 Jul 2020, 17:39Exhaust manifold heats and expands sealing the leak.
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
thats your CV outer on its way out.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- RickHaleParker
If that where the case it would not go away after the engine warmed up.vtl wrote: 10 Jul 2020, 20:14 The noise is speed-sensitive, not RPM. Something is loose in the drivetrain AFTER transmission.
Active
Past
Past
vtl
Propeller shaft gets pretty heated by exhaust in front.RickHaleParker wrote: 10 Jul 2020, 21:25 If that where the case it would not go away after the engine warmed up.
- 6043 Views
Last post by Volvogurl89
- 1938 Views
Last post by vtl
- 911 Views
Last post by GBS
- 5697 Views
Last post by MoVolvos
- 1876 Views
Last post by Marilyn99
