control arm bushes replacing without press Topic is solved
- Has thanked: 1497 times
- Been thanked: 3810 times
Re: control arm bushes replacing without press
Extracting truth from children with their thumbs....
- Has thanked: 2650 times
- Been thanked: 1240 times
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
Has anyone used XC70 Front Control Arm Rear Bushings on other P2 cars such as the S80?
Dorman provided specs for both the Standard and Heavy Duty bushing.
There is just a hair difference so should it work? Inner Diameter: 14.2 mm vs 14.1 mm.
XC70
https://www.fcpeuro.com/products/volvo- ... -8630605oe
Standard P2 Front Control Arm Rear Bushing - S80 Inner Diameter: 14.2 mm
https://www.carid.com/dorman-premium-ch ... rl=6157142
Heavy Duty P2 Front Control Arm Rear Bushing - XC70 Inner Diameter: 14.1 mm
https://www.carid.com/dorman-premium-ch ... 2389625566
XC70
- Has thanked: 927 times
- Been thanked: 999 times
If my math is correct, the difference is about 0.004 inches. This looks to me like too large to 'just press it in anyway'. I think you would have to ream out the control arm to adjust the press fit. Anyway, that's my gut reaction.
- MoVolvos
The XC bushing has more rubber but the bolt shaft has the same height. I've removed trailing arm bushings on an older Lexus years ago using the drilling and cutting method. I think this guy did ream out the control arm by sanding as the bushing went in fairly easy.volvolugnut wrote: ↑11 Jul 2020, 18:05
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I put XC90 smaller single bolt bushing on my S60 2003 front control arms. It was identical. Not sure about the large one with 2 bolts. In the above video, the bushing was kept overnight inside the freezer (and in a plastic bag prior to installing), but perhaps the most important was to render the metal surface inside the control arm hole really really smooth. May try sanding it to clean it, but I finished with a soft steel wire mesh sponge to get the surface to look like a mirror - this reduces a lot the friction coefficient which is what makes the bushing slide in easier - and I also used high pressure CV joint grease. I really recommend installing only genuine bushings from Volvo, all rubber looks the same but the intrinsic rubber properties will vary widely depending on the material quality - it's what makes a bushing last 3 months before tearing vs an identical looking bushing that lasts 5 years or more
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
Part CONTROL ARM REAR BUSH XC70 8630605
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- MoVolvos
Thanks for confirming this will work. I've wondered whether the Review on FCP for the Volvo OE was true.oragex wrote: ↑12 Jul 2020, 06:34 I put XC90 smaller single bolt bushing on my S60 2003 front control arms. It was identical. Not sure about the large one with 2 bolts. In the above video, the bushing was kept overnight inside the freezer (and in a plastic bag prior to installing), but perhaps the most important was to render the metal surface inside the control arm hole really really smooth. May try sanding it to clean it, but I finished with a soft steel wire mesh sponge to get the surface to look like a mirror - this reduces a lot the friction coefficient which is what makes the bushing slide in easier - and I also used high pressure CV joint grease. I really recommend installing only genuine bushings from Volvo, all rubber looks the same but the intrinsic rubber properties will vary widely depending on the material quality - it's what makes a bushing last 3 months before tearing vs an identical looking bushing that lasts 5 years or more
https://www.fcpeuro.com/products/volvo- ... oe#reviews
Keaton85
on Sat, Oct 27 at 01:07PM
- Great upgrade to the FWD 01+ Volvos
These should be the only bushings that can be purchased for the control arms on the P2 series Volvos. The other FWD version does not hold up well and is a much weaker design. If you want to upgrade your control arm bushings in the FWD vehicles, these are the ones to get! The only other option is Polyurethane bushings but they are $200 for a set of two rear vertical. As for the front horizontal bushings, consider using Powerflex instead of the stock bushing.
- Has thanked: 292 times
- Been thanked: 765 times
Fore the record that guy Keaton85 was super knowledgable about Volvos when he was in the game - he was a great resource on the forums.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- oragex
I also recommend poly for the front bushing with two bolts. It takes away the play the genuine rubber ones have, is this play that causes the steering to feel disconnected at center. Perhaps Powerflex last long enough, not sure about other brands. If I was to do the arms again, I would go with front poly for this reason, bonus is also easier install than genuine rubber ones.
