2004 S60 2.5T AWD Oil Change
StickyPocket
Year and Model: 2004 S60 2.5T AWD
Has thanked: 42 times
Been thanked: 6 times
Post by StickyPocket »
abscate wrote: 10 Sep 2020, 07:24 The 7th liter goes into your trunk for your spare oil. You can trade that for vaccine in the Apololyose
:D
Thanks guys! I ordered oil, filter, the Assenmacher tool, a magnetic drain plug, and the oil cap gasket.
To replace the oil cap gasket, I just unscrew the mechanism and slip the old one off? Also, how does everyone avoid spilling oil when filling? I'm thinking of cutting the bottom off a gallon water jug and using as a funnel.
2004 S60 2.5T AWD
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
- Oil Filler Cap just slides off, even with your fingernail.
- To avoid spill, use funnel or hold the oil gallon sideway (the wide part of the gallon container parallel with the driveway).
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Funnel is a great idea, often times overlooked until you spill oil over the engine. Be ready for an oil mess when removing the filter cup - surely not a job to be done on a shiny new driveway
I second getting the correct tool 86mm 16 flutes. Most have a hole for 3/8 drive wrench tip, but if a previous owner torqued this like a wheel lug, a 1/2 drive hole one is a blessing.
Speaking of oil quantity, do the turbo engines have bigger oil pan ? I can never get 5qts in my non turbo, even after prefilling the filter cup, it takes about 4.8qts to the max mark
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
oragex wrote: 10 Sep 2020, 10:16 Funnel is a great idea, often times overlooked until you spill oil over the engine. Be ready for an oil mess when removing the filter cup - surely not a job to be done on a shiny new driveway
My 2.4 takes 5.3 and my 2.5T takes 5.8 I believe.
04s60 2.4
04xc70 2.5t
Has thanked: 1610 times
Been thanked: 4065 times
A pizza box makes an excellent catcher of drips for the oil change job and cones with a free dinner.
๐Ÿ•
StickyPocket
cn90 wrote: 10 Sep 2020, 09:56 - Oil Filler Cap just slides off, even with your fingernail.
The gasket comes off and is replaced that easily? No unscrewing anything? How does it even stay in place?
2004 S60 2.5T AWD
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
You will have to coax the old one off. The lugs on the cap will require you to flex the gasket a bit. Beyond that it has nowhere to go.
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
https://www.fcpeuro.com/products/europe ... nospillkit
Youโ€™ll notice the strangest phenomenon occurring - youโ€™ll actually begin to get excited as you see your P2 closing in on its next oil change since you get to use this wonderful invention again!
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
reverend
Year and Model: 2006 V70 2.5t
Has thanked: 2 times
Been thanked: 3 times
Post by reverend »
I've had issues with the cap wrench getting stuck to the cap, and apparently I wasn't the only one as this little spider tool is highly recommended: https://www.amazon.com/gp/product/B083N1PPSY
I used to drive a lot more and change the oil every 12000 miles, so I installed a Fumoto valve to avoid dealing with a nut. It's a quarter-turn ball valve with a little spring-loaded locking tab. I stick a jack under the front of the car, slip in jack stands under the sub-frame, then I drop the belly pan (impact driver makes it a 5 second job), then slide in the drain pan and open the valve.
While that drains, I undo and replace the filter. If the rubber seal feels square or harder than soft rubber, replace it (I believe all the filters come with a new gasket - then just replace it), I tighten the filter cup just until it seats against the block again, and give it the slightest snug. No need to tighten it like a bear.
I generally get six quarts to a replacement, with a hair left in the last jug.
The oil you listed is expensive AF and if I recall right, your engine only specified ACEA A1/B1 or A5/B5 for "severe duty". I've been getting the Mobil 1 full synthetic at Costco when they're $10 off a case (six quarts), when it coincides with Mobil's $12/case rebate. That brings the case price down to ~$16, which is $2.67/quart - FAR less than the LiquiMoly.
Next, I'll use the Kirkland oil as it meets the specs (A5/B5 "severe duty") and is even cheaper. Now that I don't drive as much, I only hit 12000 miles in a year, so cost isn't as much of a big deal, but still. Why not save money if I can?
If the car is new to you, I would probably note what oil you're using and change it again in 10K miles (that's often a bit early, but if you don't know the condition of the engine, it's good to have some margins) and send in a jar for analysis.
The magnetic plugs only attract magnetic stuff, so any copper/aluminum and other non-magnetic wear won't show up on it. The oil analysis will tell you everything about the inside of the engine. Coolant, exhaust, wear from valves/stems, rings, bearings, bores, etc. It's a bit like a comprehensive blood test on yourself.
StickyPocket
reverend wrote: 16 Sep 2020, 22:11 .
Already picked up the 6L of liquimoly special tec. Will def try to save some money next time. Also got the magnetic plug. Car isn't new to me, and it was in my wife's family since new. The last oil brand was Total, and was done relatively few miles ago, like 5k, but it will be a year ago in December. I heard you want to change oil at least every year even if you don't put many miles on it. I'll look into that analysis, but I'd hope it's in pretty good shape with under 74k miles. It was dealer serviced before i got a hold of it, although it did sit unused for a little while.
2004 S60 2.5T AWD
