Unfortunately unable to find seal kit. I'm gonna get that reman MC for $45 and put that on. Can you please drop a link to the complete replacement process? About July, my friend thought that because I'm constantly working on my car (constantly changing and modding), it must be very unreliable. He said (back when I was driving my 98 XC) that I shouldn't buy another Volvo, but instead get another GOOD car. That's quite a conflicting statement. I certainly flipped that statement on him.volvolugnut wrote: 25 Oct 2020, 14:56 No, this seal shown is the seal for the tank. Neither IPD or FCP have a seal kit. Beware of off brands that may have bad rubber.
A sandpaper flapper should work if it gets the cylinder smooth and shiny.
96 960: issues with braking and brake pedal
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- Has thanked: 987 times
- Been thanked: 1078 times
I do not have detailed information on the replacement process. You will need to find this yourself. I think you made good choice to replace the entire MC. First, I would see if you get nasty fluid out of the system. You may be able to just look in the tank and see it is nasty fluid.
- CIK7
I just checked and the brake fluid seems to be really clean. There is a little dark residue on the side of the inside.volvolugnut wrote: 26 Oct 2020, 08:26 I do not have detailed information on the replacement process. You will need to find this yourself. I think you made good choice to replace the entire MC. First, I would see if you get nasty fluid out of the system. You may be able to just look in the tank and see it is nasty fluid.
The dark stuff is likely rust.
You will need either a willing helper or a vacuum pump to bleed your system.
- CIK7
Yes I have a friend that lets me come over to his place for major jobs. He helped me when I had to change the brake hoses on my 98 XC. He's got 40y+ of experience. If anything, I can stay home and use small and large cinder blocks. I think while I'm at it, gonna change the brake hoses. Must be pretty cracked at 19 years of use. I've already added them on eBay. About $45 additional. Unfortunately, the seller for the $45 MC just happened to 'go on vacation' until at least Nov 2. What a turd because I was planning to go to Oklahoma City the 2nd or 6th.volvolugnut wrote: 26 Oct 2020, 09:06 You will need either a willing helper or a vacuum pump to bleed your system.
Two warnings:
1. Don't use cinder blocks to support the car. They crush and the car will crush you.
2. Don't take chances with failing brakes. Fix them.
volvougnut
volvougnut
- CIK7
Well I'm gonna use the blocks for pressing the brake pedal. And that's good advice, I could wait til I fix them. Thank you.volvolugnut wrote: 26 Oct 2020, 09:38 Two warnings:
volvougnut
- 4760 Views
Last post by SUBdude
- 4112 Views
Last post by 204015953
- 7028 Views
Last post by 850forum
- 809 Views
Last post by wizechatmgr
- 1019 Views
Last post by zjevik
