Upgrade turbo without tune?
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
abscate wrote: 19 Mar 2021, 04:45 Check the 50 cent copper washers on the oil lines before you tear it down
Good catch. Expansion and contraction due to the wide range temperature changes could deform the sealing surface.
Active
Past
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
And the $6 oil return line seals.
Has thanked: 2205 times
Been thanked: 1852 times
When did you last replace the PCV system? If that is blocked it will eventually poor oil down the back of the block onto the turbo.
I would clean it all off and then see if you can find a source of the leak. It may not be the turbo as suggested.
