Leak from fuel tank when filling up! Topic is solved
ashleyg82v702001
- Year and Model: 2001 v70
- Been thanked: 4 times
The repair was finished after finding fuel safe silicon fuel hose to use as the pipe joiner.. This has worked perfectly and the car sails through mot inspection... I used cv boot clips to secure the pipe in place and it looks intentional and factory standard.. No leaks and it is still holding strong..
- Has thanked: 2202 times
Thanks for the update. We always appreciate the close out for those who my need the info for the future.
jeffwhite
- Year and Model: 2003 V70 auto petrol
V70 2003 petrol auto. Same problem, fuel leak whilst filling. Big pool on the ground. Eliminated everything other than the rubber hose connection to the tank. Impossible to access from under and simply could not drop subframe and tank for access. Because the car only has a few year left, decided on something drastic. Spare wheel well, cut out a large enough section in front of connection position (drilled holes rather than risk sparks from angle grinder). Opened up enough for decent access - approx. 250mm wide by 250mm high. Looked drastic and involved a lot of cosmetic finishing after the job. But, success. Old rubber had perished and my 'inspection hatch' was large enough to get the job done. All in all, I know this is a traumatic task, but for me there was no other choice, and it worked.
- Been thanked: 4068 times
Well done, Person of Kent!
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 67 times
- Been thanked: 93 times
Cutting fuel system access holes is a risky modification. Some fuel tanks used to be located inside the trunk area of cars (Mustang, Jaguar, Mercedes) and during extremely strong rear impacts, the fuel tank would be crushed and spray the interior of the vehicle. Many car companies run a non-regulatory crash test directly into the filler pipe to verify that the impact doesn't cause a leak or other fuel system problem. Almost all fuel fill caps have a strap to prevent loss. These items are "lessons learned" following the Ford Pinto thermal problems in the 1970s. Cutting access panels to the fuel system creates a risk for fuel to spray into the vehicle in a really bad rear impact. I was rear ended twice during 2021 in construction zones on Interstates 75 and 94 when people didn't notice that traffic was stopped. Both vehicles were non-Volvos and I was lucky to not be hurt.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
- 367 Views
- 1254 Views
Last post by oragex
- 870 Views
- 16 Replies
- 885 Views
Last post by Brickbox8398
- 1821 Views
Last post by BrianV70
