Engine self-destruct
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
In wonder if this is similar to the infamous "burned valve" issue we see in P80 cars (1993-1997 850, 1998-200 s70, V70 etc.)...Most commonly cylinder #3...
Post by cn90 »
Next: do a compression test, dry and wet.
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
If you had bottom end damage, you wouldn't be asking about it. You'd be diving for cover and tightening your helmet.
If you have piston damage, you'll have zero compression, but you'll see that with the boroscope.
+1 compression test is next. If it's down, pull the head, strip it, send it out to have the valve seats lapped, and when you put it back together, replace any damaged valves.
5 others that came and went
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
research says they fitted the faulty engine killing banjo bolts from 2005 2.5ltr, so my 2001 2.4ltr should be safe? its going to be a while until i can remove and check it.
engine killer banjo bolt
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Thanks for sharing that info. I didn't know about the banjo bolt problem.
BMW 540i 2002
S70 Base 2000
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
darylrobert wrote: 05 Jun 2021, 03:07 research says they fitted the faulty engine killing banjo bolts from 2005 2.5ltr, so my 2001 2.4ltr should be safe? its going to be a while until i can remove and check it.
With the latest banjo bolt design it looks like the retaining pin is held in place with a through hole crosswise in the bolt. I believe this bolt has 2014 on the head if you want(can) to check which banjo design currently installed in the manifold.
Banjo bolt 31325709.jpg (35.93 KiB) Viewed 1004 times
DonnVa
Year and Model: 2005 XC70
Has thanked: 21 times
Been thanked: 61 times
Post by DonnVa »
Well damn, when I did my PCV last summer, mine was the old style and all I did was clean it out w/ some carb cleaner. I already had an alternator pulley and decoupler tool in my FCP cart. I just added the new banjo bolt. I should be able to get to it okay w/ the alternator out. Pulley job just got extended.
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
Zolll
Year and Model: 2004 XC70
Has thanked: 2 times
Post by Zolll »
DonnVa wrote: 05 Jun 2021, 16:01 Well damn, when I did my PCV last summer, mine was the old style and all I did was clean it out w/ some carb cleaner. I already had an alternator pulley and decoupler tool in my FCP cart. I just added the new banjo bolt. I should be able to get to it okay w/ the alternator out. Pulley job just got extended.
Good for you.. I wish I would've known about the stupid bolt back when I replaced my PCV parts years ago..
Anyone knows it I can just disconnect the exhaust manifold and pull the head out or should I also remove the turbo?
