I’ll guess you didn’t quite seat the cam sensor reluctor wheel on the VVT cam and it’s hitting the sensor. Does it sound like the worlds loudest mouse chewing on stuff?
A very close friend of mine did this once on a 1999 V70 T5 M56 in Nautic Blue
Massive Oil Leak
- Has thanked: 1611 times
- Been thanked: 4072 times
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
Yep. Sounded metal to metal.abscate wrote: 07 Nov 2021, 06:07 I’ll guess you didn’t quite seat the cam sensor reluctor wheel on the VVT cam and it’s hitting the sensor. Does it sound like the worlds loudest mouse chewing on stuff?
Oka
May I ask what your friend did to solve this issue?abscate wrote: 07 Nov 2021, 06:07 I’ll guess you didn’t quite seat the cam sensor reluctor wheel on the VVT cam and it’s hitting the sensor. Does it sound like the worlds loudest mouse chewing on stuff?
I’ll ask him next time I see him.
Ok, you removed the reluctor, the little metal cup that bolts to the back of the cam, and found that it seems to sit right in many positions but only goes in one way correctly. It will sit nice amd flush and square with respect to the cylinder head when right
Oka
The cap, I did right, am sure. My bad, it should ONLY fit one way.abscate wrote: 11 Nov 2021, 03:25 I’ll ask him next time I see him.
Thanks
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
That happened to me too. Must have been some small crack i couldnt see. Very odderikv11 wrote: 21 Aug 2021, 09:03 I had a leaky oil filter cup looked a lot like that unless it was really really tight. Tried replacing the gasket no go. I ended up getting a new one solved the problem, never figured out how the old one was bad.
BMW 540i 2002
S70 Base 2000
TisMe
- Year and Model: 2001 & 2004 XC70
- Has thanked: 42 times
- Been thanked: 17 times
I would go ahead and pull that engine mount back off, and retrace your steps back toward to the far exhaust cam seal, then play with the reluctor wheel. Just for fun
from the maintenance you listed, I don't see what else could make the described noise.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
Retracing is a good approach, could very well be the motor mount itself.TisMe wrote: 11 Nov 2021, 18:54 I would go ahead and pull that engine mount back off, and retrace your steps back toward to the far exhaust cam seal, then play with the reluctor wheel. Just for funfrom the maintenance you listed, I don't see what else could make the described noise.
WHen I lost a coil the engine made a knocking noise under load ( on 4 cyls) , turned out to be the motor mount.
The noise went away when the coil was replaced.
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
Oka wrote: 06 Nov 2021, 20:13 Finally finished and put everything back. Been busy with other things. Here are the work I did.
- Front crank seals, intake and exhaust side
- Water pump
- Timing belt, serpentine belt
- Timing belt tensioner
- PVC breather and oil trap
- Pulled down the oil pan and cleaned
- All o-rings in the area I worked
However, I connected the battery, started the car, and it sounded bad, like grinding teeth; I turned the car off right away.
What on earth could that have been?
Cheers
If you hear metal to metal type grinding noise when you started the car you should also hear something when turning the engine over manually. Take the spark plugs out to make it easier to turn over the engine manually from the crank pulley nut and with helper listen carefully for the sound, you should at least be able to pinpoint where the sound is coming from.
- 1836 Views
- 1400 Views
- 1655 Views
Last post by thepope540
- 1683 Views
Last post by vtl
- 2792 Views
Last post by rguzz
