Hmm I'll have to take the throttlebody off later today and see if maybe I was mistaken about the welds. Too bad i took the time to clean that new one instead of the old oneSveedy wrote: 28 Aug 2021, 12:49 The few throttle bodies I have tinkered with had some sort of hard epoxy dabbed on to the throttle plate screws. I assumed that it was done to prevent the very rare case of one of the screws working loose and being ingested into the engine. When I switched plates I used a little loctight instead.
Differences in n/a 850 Throttlebodies? Topic is solved
Luttrell
- Year and Model: 1994 850 n/a
- Has thanked: 5 times
Luttrell
So it was epoxy after all, after some poking and prying i managed to get the old throttlebody disassembled. Ended up using the best parts from both throttlebodies and got the new shaved plate installed and man the throttle response was significantly improved. The car doesnt feel any stronger necessarily but it definitely feels quicker.
Thanks for the responses everyone, I look forward to making more progress with this car, namely that VVIS switch that user razorx created on the thread linked below.
N/A tuning 20V, VVIS, something diffirent.
- Has thanked: 2210 times
Well done. Thanks to some good input from Sveedy you hopefully have got a permanent solution.
- 3187 Views
Last post by skloon
- 11 Replies
- 3057 Views
Last post by tryingbe
- 1343 Views
Last post by ZionXIX
- 1327 Views
- 1095 Views
Last post by hausmeister
