Please Help with this Popping Noise
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
zakmuh wrote: 09 Dec 2021, 11:17 I have to replace the cylinder head. Oh well!
We now know what the popping was. It was compression existing through the intake valve.
Should not be too much of a chore. You British have a long history of putting heads on the block. :wink:
Active
Past
zakmuh
Year and Model: 2003 XC90 D5
Has thanked: 6 times
Post by zakmuh »
Lol yeah we do. I'm gonna look for a refurbished one on eBay. Getting the exhaust manifold removed will be a pain taking job.
Thanks for help with getting to the bottom of this issue.
Could I please get your brain on this one....I put everything back. Engine cranks but wouldn't start. I think ECU connection issue? No warning lights - just wouldn't start.
When I started (cranked) it first, it sounded like a fan working. Kept on cranking with 5 sec intervals. After the 5th crank it started to crank how a proper starting up would sound and thats it....
Fault codes:
Diesel (D5244T4 - Diesel - MT/AT)
DTC Description
23A0 - Injection valve 1
- Signal missing
23B0 - Injection valve 2
- Signal missing
23C0 - Injection valve 3
- Signal missing
23D0 - Injection valve 4
- Signal missing
23E0 - Injection valve 5
- Signal missing
2430 - Fuel system
- Faulty signal
6664 - Glow plug control
- Faulty signal
6662 - Glow plug control
- Faulty signal
zakmuh
Post by zakmuh »
I have to mention this...Further to what I've said above, I didnt crank it continuously. In the end, first came Battery low message followed by engine system service required. Thats when I plugged the scanner and got the code.
Is it okay keep cranking for a over a minute? This wouldn't knacker the starter motor?
I've put the battery to charge overnight.
RickHaleParker
Clearly a electrical issue. Check your electrical connections.
The injector valve codes are all open circuit. Did you reconnect the electrical wiring back up?
The Glow plug can also be open circuit or high resistance. Did you reconnect the electrical wiring back up?
Active
Past
zakmuh
Post by zakmuh »
Yeah, I ran through all the connections multiple times.
I disconnected the battery well before working on things and then connected it back only after everything was put back, just before cranking.
RickHaleParker
zakmuh wrote: 10 Dec 2021, 13:19 I disconnected the battery well before working on things and then connected it back only after everything was put back, just before cranking.
Get the battery charged back up. When you reconnect the battery. Positive first, turn key to POS II ( Run ), connect Negative. That will force the control modules to reinitialize.
Active
Past
zakmuh
Post by zakmuh »
Will do mate and update you tomorrow
Cheers
zakmuh
Post by zakmuh »
Morning Rick, Hope your weekend is going all good as planned.
No luck...I tried your way but still the same. Just a thought...Could I have placed the camshaft incorrectly? Like just 1 tooth misaligned?
zakmuh
Post by zakmuh »
Removed everything again and checked. Single dot on the intake shaft (right) is in the middle of double dots on the exhaust shaft, as shown in the pic.
I didn't do the camshaft adjustment as per VIDA. This could be the reason for not starting?
zakmuh
Post by zakmuh »
More pics from high pressure pump and vacuum pump side...
