Changing out the Fuel filter
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1076 times
Post by volvolugnut »
The fuel manifold is the shiny straight tube in the center of xheart's photo. The fuel bleed valve is in the tiny blue cap on the right end of the manifold. The manifold may have plastic cover (Item 4). But you should not need to remove this cover.
But you knew that.
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Fuel filter can be a pain to replace due to rust - remove the bracket first and then work with separating fuel hoses.
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
I threw on a new Mahle fuel filter today. Didn't even bother to raise her. My garage slab is fiber concrete so easy to lay your back on. Don't know if all P2s have it but there's also a schrader release valve on the fuel hose right next to the fuel filter. I just released gas there then changed the filter within 10 minutes.
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
A whisper of silicone grease on the new filter's "males" helps.
No relief valving on mine.
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
For others picking up this thread... I just did this on my 2008 and pulled the fuel pump fuse to run the car dead and relieve pressure. To my surprise there was a Schrader valve at the fuel filter to drain the remaining fuel out into my drain pan, pretty handy. Don't recall having that on my 2002.
Feels like I picked up 20 horsepower after the filter change.
:lol:
08 C702.5T (sold)
The non-Swedes:
