Heh gentlemen. Just wanted some reassurement before I change the oil for the first time on my new/used 2002 V70.
My old S70 had the solid metal one piece filter but apparently this one has a rubber o-ring that needs to be seated along
with the filter cartridge.
When I remove the housing, is the o-ring seated in place around the old filter so I can repeat the same procedure?
Thx much!
Changing out the oil filter
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
The o ring is fitted to a track on the filter canister. It stays in place when the filter is taken out so you can easily just out the new one in the same place. Don't forget to lightly lube the new o ring so that it slides into to place easily.
Mr. Detail
Thank you kindly Mr. Rattnalle.
The oring goes on the outside of the plastic filter “ cap”
Remove the old with a pick, put the new one in the right groove in the cap.
The old oring can be washed in the dishwasher and used as a hair band.
Mr. Detail
abscate;
I would love to give the old O-ring to my teenage daughter for that use?
"The old oring can be washed in the dishwasher and used as a hair band."
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
I could have saved so much money on hairbands already in my house of girls if I had known
Now, if they would make them in different colors....
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 79 times
- Been thanked: 71 times
Hey OP, Don't the other V70's in your stable (the '04 and '05) have the "O" ringed housing w/element filter? Just askin'
Mr. Detail
Georgeandkira,
There is only one V70 in my driveway. You must have me mistaken for someone with $$.
My previous Volvo was a '98 S70. This is my first Volvo with an "o-ring" dealio.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The oil filter cap only needs to be tighten until it stops. The o ring seals due to placement and has nothing to do with torque on the cap. If it is tight then there is risk that the cap socket wrench slips on the little flats on the cap.
That will get everyone's attention.
- 2484 Views
Last post by instarx
- 14 Replies
- 2182 Views
Last post by Krons
- 15 Replies
- 2962 Views
Last post by 454cid
- 2249 Views
- 935 Views
Last post by precopster
