Windshield washer check valve?
Has thanked: 2215 times
Been thanked: 1853 times
It does stop it draining as it is a one way valve. Once closed water dos not drain back down as it is in vacuum.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
scot850 wrote: 10 Feb 2022, 15:58 It does stop it draining as it is a one way valve. Once closed water dos not drain back down as it is in vacuum.
I never thought of it that way. I did actually use vacuum to change the valve on the bottom of my water heater in my house. Close the intake and outlet valves on top and most of 40 gallons is held inside while I removed the leaky drain valve on the bottom.
I did notice that the driver's side hose looked a little different than the passenger side, so maybe I've had one or both check valves removed and replaced with simple fittings, at some point by someone not knowing any better, or maybe just an internal failure.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
