Smart. That spring is a little rocket!markone wrote: 25 Apr 2022, 07:21 I have not been able to source the attaching spring, so I will have to be careful in the swap-out.
850 Corner light specification help, please
- Has thanked: 2857 times
- Been thanked: 1332 times
- Has thanked: 2203 times
Is the spring not part of the replacement unit? I thought they came with them.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Volvo ones do.
It seems that aftermarket ones doesn't.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
rick4484
- Year and Model:
- Has thanked: 59 times
- Been thanked: 10 times
My 96 850 has been sitting for some months and today I noticed the driver's turn signal light assembly dangling by the electrical wire. When I examined it closer I noticed the plastic part on the body of the light, where the spring attaches, was broken. I'm assuming the plastic was just brittle and the spring tension caused it to break. Online advertised cost of the part for genuine Volvo, #6817769, is somewhere between $64.00 and $120. eEuroparts has theirs for $28.64 each.
I thought about ordering one from a dismantler, but the problem with weathered plastic is you're getting something that would most likely be a short term fix. If the eEuroparts assemblies are a decent replacement, I think I would order and replace both sides.
I'd like to know how different the genuine part is from the oem part. Is there a difference in fitment, illumination, installation?
- Been thanked: 4068 times
Get a $1 bungy cord from Harbor Fright and secure your signal to the frame with light tension
- misha
Genuine (oe) have Hella in the upper part and Volvo in the lower part.
Oem ones have just Hella or Valeo(same quality as oe just without Volvo lettering).
Some aftermarket ones comes without attaching spring,as our member pointed out.
Depo is good aftermarket replacement...don't know about other aftermarket brands...but if you stick with good known aftermarket brands it will be fine.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 253 Views
Last post by Wackneck
- 656 Views
Last post by erikv11
- 1501 Views
Last post by cn90
- 1966 Views
Last post by RickHaleParker
- 345 Views
Last post by kahl
