Rotor arm is what it is called in the good old UK where I learned to wrench (spanner!) on vehicles!
96 850 Turbo: Codes P0302 P1310 - problem ONLY during idle
- Has thanked: 2210 times
insession
- Year and Model: 1996 850
- Been thanked: 2 times
Surprisingly, codes and symptoms remain after thorough cleaning of distributor parts.
Issue only seems to arise when in gear, at idle, with either foot on brake, or letting it crawl at idle speed. Then, it runs rough, jerks, vibrates, staggers. At driving speed or under full turbo load or at revs even past 5000, it runs great.
While driving, at intersections, when putting lever into N, idle stays stable, but at differing revs: about 900, 1200 or 1600.
Any clues?
Thanks,
Peter
Any clues?
Thanks,
Peter
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
You can still have bad wires after cleaning. I had a mystery just like yours that would happen at wierd times. It took a year to generate a misfire code. I dont know if you have a second set of known good spark plug wires to trade out one at a time and see the difference.
insession
Regret I don't have the old wires anymore. Ordering new Bosch rotor first (while ordering heater core as well from FCPeuro - gotta replace it, have oily smelling fog coming out of vents - fun!
Have you checked all the various vacuum hoses for leaks?
Have you checked fuel pressure at rail? 42+ psi for your year.
- Has thanked: 2864 times
- Been thanked: 1332 times
+1scot850 wrote: 02 May 2022, 19:30 Have you checked all the various vacuum hoses for leaks?
I know in the US you can often rent the tools from some of the parts stores. I am not familiar with the stores but try Autozone or the likes.
Or you can usually get a quick test using a mechanical tire pressure gauge on the Schraeder valve on the fuel rail. Use a cloth around the tire gauge while pressing on the fuel rail and see what it gives you. It may not show 40+ psi but it should be close if all is well. A proper fuel system gauge is obviously better if you can borrow one.
- ZionXIX
Really? Does this ruin the tire gauge at all? This would make road side testing a little easier when you don't have access to the right gauge.scot850 wrote: 02 May 2022, 22:28 I know in the US you can often rent the tools from some of the parts stores. I am not familiar with the stores but try Autozone or the likes.
- 1531 Views
Last post by WhatAmIDoing
- 1659 Views
- 1213 Views
- 1677 Views
Last post by RickHaleParker
- 11 Replies
- 2045 Views
Last post by greg850r
