2001 S60 Any preventive maintenance proposal? Topic is solved
S60 Preventive Maintenance Parts
zoli_m13
- Year and Model: S60 2001
- Has thanked: 1 time
- Been thanked: 2 times
Battery replacement after 2 years + putting epoxy glue onto the broken inside door handle at the driver's side door.
2001 VOLVO S60 2.0T A/T 245K+ miles
https://goo.gl/photos/jS1z777LDqJSQqPDA
zoli_m13
Cabin filter change after 2 years and ca. 20K miles; no bad smell realized.
Both has activated carbon layer:
Out: Mann CU2855
In: MAHLE LAK54
Out: Mann CU2855
In: MAHLE LAK54
zoli_m13
Removed that old fashioned cigarette lighter and retrofitted by some useful tools.
The socket came out very well, but its size was smaller for this USB connector: a hole polisher in the drill did the job.
Advantage: there is a dust cover reduces the light of the blue numbers at night.
Good DIY instruction found here:
viewtopic.php?t=27171
Marcobrick
- Year and Model: 2003 V70T5
- Has thanked: 3 times
Hello Zoli! I have just read through this whole amazing thread. You keep very good care of your Volvo.
I have a question for you. When you removed the factory fitted phone, did you get any error messages? I want to put in a cup holder like you did and get rid of the useless phone, but I was wondering if there are CANBUS errors if it is removed.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
Marcobrick
Many thanks. I was hoping it would be that simple, but you can never take that for granted with modern cars!
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
zoli_m13 wrote: 03 Mar 2019, 02:37 Removed that old fashioned cigarette lighter and retrofitted by some useful tools.
I also have one of these battery voltage meeters - It is an excellent idea. In fact it is only an alternator measure because when the engine if off, the voltage shown is that of the battery minus the dome light, computers, etc so it's not accurate for reading the battery, but good for reading the alternator. This will save your battery if the alternator has a problem: you can see the problem before the battery goes bad. I've tested mine here
zoli_m13
Oil change:
- out: Total Quartz Energy 9000 5W40, Mahle O/F
- in: Shell Helix Ultra 5W40, Mahle O/F
- mileage: 2K Miles (cleaning)
zoli_m13
Well, Folks, I figured out focusing on the ABS sensors in terms of
1. cleanliness and tighthness in the hub
2. fine electrical connection in the plugs
Symptoms:
1. Illuminating DSTC light and error message (DSTC WART. ERFODERL.) going over a bump or at sharp cornering
2. Restarting the car: no DSTC light till going over ...
Step-by-step procedure:
1. Disconnected the battery negative terminal (driver's side door and trunk left open)
2. Unplugged all 4 ABS sensor connectors (2 front are at the firewall, 2 rear are under the rear seat - see the photos below) - use a flat screwdriver to push the small tab before pulling
3. Checked the resistance: read between 25 and 120 ohms (jumps quickly) - all 4 had the same values; applied some WD40 in it
4. Removed all 4 ABS sensors from the hub by a 10 mm socket and a wire has L shape (came from the bread maker
) - only minor pulling force onto the electrical wire); its seat cleaned by a strong glass washer brush
5. Good news: some dust found on the sensor's bottom part - not remarkable debris found
6. Key turned position #2 and connected the battery negative terminal
7. Key removed, pushed the unlock button on the remote controller
8. Key turned into position #1 for recalibrating the ventillator (turning the knob to min and max position), reprogramming the radio (pushing AUTO button) and setting the time in the instrument cluster
9. Test run: no issue detected - hoping not later
Cheers!
Connectors:
ABS sensors:
Symptoms:
Cheers!
Connectors:
ABS sensors:
- 19 Replies
- 3185 Views
Last post by befarrer
- 11 Replies
- 2893 Views
- 2424 Views
Last post by rdl1996
- 1895 Views
Last post by jlh3rd
- 2890 Views
Last post by packetfire
