Volvo Radio Light Bulb Replacement
cdnbluez
- Year and Model: 09 C30/98 V70/99 S70
- Been thanked: 3 times
I pulled one of the burnt bulbs from the holder, it was wound on pretty tight. I'm not sure I could do the same, does it have to be as perfect?
2007 C30 T5 6 Speed
2005 S40
2006 XC70
2014 Mercedes E350
1996 Corvette Convertible LT4
Previous Volvos:'09 C30 5 speed, '99 S70, '99 S70 5speed, '98 V70 SE, '04 XC70, '01 V70, '02 V70 awd, '97 855, '90 745 Turbo+, '90 745 16v, '89 780 Bertone Turbo+, '86 760 Turbo+, '82 240 GL
2005 S40
2006 XC70
2014 Mercedes E350
cdnbluez
Went the Radio Shack route, 2 for $4.99. Holders are brittle, so you have to be careful when removing old bulbs. Works perfect.
2007 C30 T5 6 Speed
2005 S40
2006 XC70
2014 Mercedes E350
2005 S40
2006 XC70
2014 Mercedes E350
BlackXC90T6AWD
- Year and Model: 04 XC90
okay i got the replacements for these bulbs off Ipd but i took these bulbs out a while back and lost them therefore i lost the blue gels on the bulbs i put the ipd bulbs in and they give off a red light and hte oens that arent burnt out and that werent take out give off a white light so i had to take all the bulbs out and take the blue gels off so it at least all matches. but they look just god aweful is there anyway i can buy bulbs that have the blue gels for my entire front console im talking the heating and audio controls anyone who can help me with this please do it looks sooo terrible!
Problem found and fixing it at the moment.sakiduz wrote:Hello, I have problem. Then I changed bulbs, noone ligts upBefore that, only one bulb glowed. Any ideas where is problem?
* sorry for my bad english
voodoorobaz
- Year and Model: 1982 Volvo 245 DL
After doing this job I thought I would post the updated part# I recieved from the Honda Dealer. 35505-S84-B02 is the new number. Not much different but it is current.
1998 Volvo S70-Gone
2002 Volvo S60 T5-Gone
2000 Volvo V70 XC AWD-Gone
1983 Volvo 245 Dl-Gone
1982 Volvo 245 DL
2013 GMC Terrain with 3.6l
2006 Cannondale Bad Boy Use for Commuting to work
1982 Volvo 245 DL
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I have several radio light bulbs if anyone needs some. I also have bulbs for the control switches like the sunroof, fog light switches. PM me if you need some.
Thank you for an excellent guide to bulb replacement. Easy to follow and understand. I sourced bulbs from ebay got a pack of 10 for £11.50. Unfortunately, the radio dash still does not light up. Everythings works fine on teh radio/CD/casette player but the lights. Any suggestions on what might be the problem or what I can do fic problem?
Ona separate note I also followed the bulb replacement for the gear shift light (volvo s70 saloon) and thatfixed teh problem.
- rspi
Contact rspi..
Not sure if you seen my instructions but they may help.
http://atthetipwebs.com/technologyinstr ... _volvo.htm
My guess would be that your problem likely lies with the ribbon connection. Unplug it and reconnect it. Be careful because they do separate sometimes.
- Been thanked: 504 times
Related question, the POWER button (to turn radio ON and Off) seems tired.
I can turn the radio on and off but hear no click.
Is there info somewhere what on/off switch from RadioShack can do this trick?
- 4182 Views
Last post by silentcircuit
- 1480 Views
Last post by pkc303
- 4915 Views
Last post by adrian22
- 2665 Views
Last post by firstv70volvo
- 2566 Views
Last post by mika
