DIY: Oil Pan/Sump O-Ring Replacement 2000 XC
This topic is in the MVS Volvo Repair Database » Oil Pan/Sump O-Ring Replacement 2000 Volvo XC
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Richard99 wrote: 08 May 2020, 19:41 Would anyone that has done this recommend taking the engine/transmission out if other tasks are needed. Was considering doing a pan reseal, timing belt job, and head gasket/valve stem seals all in one go.
I'll add oil pump service to complete your lubrication system overhaul using gasket kit such as this, Volvo part #274260
...after cleaned pump
You may find this thread relevant viewtopic.php?f=9&t=61449&start=1
manovlov
Has thanked: 675 times
Been thanked: 164 times
Post by manovlov »
Amazing job ! However I drive my 850, what a job !
Thanks a lot for this tutorial .
Manov
Has thanked: 1611 times
Been thanked: 4075 times
Tabulating part numbers for the 1999 model with biscuit oil cooler, from volvo parts webstore
Note 19b oring is shown as NLA but is the same part as the turbo drain line, which is still available
What would complete this thread is someone measuring the
8642559
8642560
Oring dimensions for reference here.
I’ll try look at my stash
