2001 V70 2.4T ATF simple Drain and Fill...
This topic is in the MVS Volvo Repair Database » Volvo V70 Transmission Drain and Fill Tutorial (2001+)
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
BlueRubber wrote: 26 Jan 2018, 04:33 Sorry to drag up an old thread, but I need to change the ATF in my V70.
Is there any chance you could re-host or re-upload the photos from your write up E170_Driver?
Thanks in advance from over the pond!
Same as here, just skip the part with going under the car to drain the sump. The clip at the return line may break so it's good to have a spare one ready. The return line is very hard to remove the first time, keep the green clip depressed and pull strongly on the line. Use a 3/8 tube
BlueRubber
Year and Model: v70 2002
Has thanked: 7 times
Post by BlueRubber »
Thanks for the link oragex ! :)
Mikele82
Year and Model: XC70 04 + C30 T5 08
Has thanked: 30 times
Been thanked: 3 times
Post by Mikele82 »
Cant see pictures, can someone re-upload them please ?
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Mikele82 wrote: 26 Feb 2019, 12:23 Cant see pictures, can someone re-upload them please ?
The original quote was A picture is worth ten thousand words.
SIMPLE D&F is safer if you are new to this task. CN90 says to "keep it real simple" and do it like an oil change routine, but every few hundred miles -- spread it over 4-5 routines to replace most of the old fluid. AND then line it up with actual oil and filter change schedule for upkeep.
ATF flush aka Gibbons Method takes resetting fluid counter with VIDA, and few drive cycle for adaptation. It could open a can of worms.
What pix do you need to get started?
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
"Gibbons" method, not Gibson.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
JKXC
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 5 times
Post by JKXC »
Just wanted to say thanks to everyone for the info.
Just did my '05 XC70 which I've inherited from my parents. 160,000 miles, most of those in the Texas heat and there's no service record of the fluid being changed. Regular commuter/highway miles and no towing. Prior to the change the transmission was pretty normal -- which just some bogging in shifting down from 4-3 on occasion which was noticeable. It seemed a little bit "lazy" in not wanting to shift when under load.
First checked the level at 80C using Vida to confirm where it was before doing this. Did a drain and fill, got 3.3L out of brown but not burnt smelling fluid. Magnetic drain plug had a pretty gooey, gray paste on it that took some wiping. No metal seen in the fluid. Put 3.3 of Aisin Warner 3309 in and reset the fluid change counter with Vida -- which I know is a debatable topic (and not entirely necessary) but IMHO it makes sense to start with a reset counter and not inherit 15 years of data with the new fluid (and just to be clear for those who are new to this -- this is not resetting the transmission adaption). It is strange to me that there's no way to access the actual data of the fluid counter (that I know of at least).
Took it out for a test drive and it was a noticeable and good difference. It shifts a lot more and quicker now, the downshifting slowness is gone. The only thing I noticed was a few harder downshifts when off the throttle. I'm sure once the TCM adapts to the new fluid things will change a bit. I was pretty leery about doing this given it's mileage but definitely glad I did.
Plan is to do another d&f in about 200mi, then the Gibbons method perhaps. Doing another d&f b/c I thought I had a crush washer but didn't, although I have to admit I kinda like the simplicity of the d&f method. But we'll see. On the next one I'll see if I can snap some photos for the article since they are missing.
Has thanked: 1610 times
Been thanked: 4068 times
Thanks , will look forward to pictures.
Magnetic drain plug was had a pretty gooey, gray paste on it that took some wiping. No metal seen in the fluid.
That gooey paste is metal/abrasive from the clutches But that is totally normal.
Reminder ..it’s good to renew o-rings the first time you do this, and have new clips on hand too.
cleven479
Year and Model: 2001 Volvo V70 T5
Post by cleven479 »
Great read! im replacing my trans next week and ill be doing this.
StickyPocket
Year and Model: 2004 S60 2.5T AWD
Has thanked: 42 times
Been thanked: 6 times
Post by StickyPocket »
Did this today thanks to this write up. First time after ~79k miles. Make sure you pull off the old crush washer - mine was stuck on. Fluid wasn't burnt, but was definitely dirty. Seems I got around 3.25 L out, but maybe the container wasn't accurate. Put the same amount of Toyota T4 in. Old and new fluid for comparison:
2004 S60 2.5T AWD
