> When i did p2 my first 2 pin was always the same and now im getting random pin.
Was it always the right pin bytes?
Vida CEM swapping
- RickHaleParker
- Been thanked: 980 times
The CEM is responding. I don't think turning the key on will make a difference.blasaab wrote: 11 Nov 2021, 12:26 I dont know if im doing something wrong. When i did p2 my first 2 pin was always the same and now im getting random pin. Should i add resistor or ignition on? Does my reads looks ok?
I don't use terminating resistors on mine because the resistance at the OBD port proves the CEM is already terminated. The only time I use terminating resistors is on the bench. But that was with P2. Measure the resistance at the CAN pins of the OBDII connector and post the measurements.
You are having trouble cracking everything you try to crack. The common factor is the cracker hardware. Post some good quality pictures of your hardware. Maybe one of us can spot something.
Active
Past
Past
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Do you have current logs (for when it fails)?blasaab wrote: 11 Nov 2021, 12:53 On P2 I could see like 65 78 as first pin every time and T5luke told me first 2 pin was correct and finaly after several Times it was succesfull.
- RickHaleParker
Some of the fails might be due to low or weak voltages. There are a lot of people running around with a marginal battery. Somewhere down the line a battery voltage check might be a needed addition. The question would be at what voltage would one call it a no go.
Active
Past
Past
vtl
The most recent commit (https://github.com/vtl/volvo-cem-cracke ... 5badd3b094) changed the way how the candidate is elected. I would guess, it may break some cases, though unintended.RickHaleParker wrote: 11 Nov 2021, 20:13Some of the fails might be due to low or weak voltages. There are a lot of people running around with a marginal battery. Somewhere down the line a battery voltage check might be a needed addition. The question would be at what voltage would one call it a no go.
- RickHaleParker
The shortlist method appears to work better then the old algo.vtl wrote: 11 Nov 2021, 20:25 The most recent commit (https://github.com/vtl/volvo-cem-cracke ... 5badd3b094) changed the way how the candidate is elected. I would guess, it may break some cases, though unintended.
I'm thinking some of the fails maybe electronics not code. I have seen some of mine fail to crack when the battery voltage got low. Cracked after bringing the battery charge and voltage back up.
Active
Past
Past
vtl
I see that too, with CEMs/dumps I have in my lab.RickHaleParker wrote: 11 Nov 2021, 20:54 The shortlist method appears to work better then the old algo.
Right. This thread confirmed it many times that the quality implementation is the key to success.RickHaleParker wrote: 11 Nov 2021, 20:54 I'm thinking some of the fails maybe electronics not code. I have seen some of mine fail to crack when the battery voltage got low. Cracked after bringing the battery charge and voltage back up.
- RickHaleParker
Every last one of the V50 EWDs ( Electrical Wiring Diagrams ) are online ... in multiple languages. The EWDs have the connector pinouts. It is not straight forward but there is enough information that you can map out the pins. It will take some legwork.
4/56 is the CEM.
Schematic:
Connector:PIN
Example A:1 = Connector A : Pin #1
Connectors:
4/56A is connector A on the CEM.
4/56A:1 is pin #1 of connector A on the CEM.
Same goes for connector B, C, D, E, F, G, H
If you are looking to extract the dump file.
Active
Past
Past
- 9972 Views
Last post by RickHaleParker
- 10371 Views
- 27 Replies
- 31792 Views
Last post by cn90
- 12231 Views
Last post by jonesg
- 7147 Views
