It is only about 8-10cm long. It comes off the top of the turbo and connects it to the long metal pipe that runs over the top of the engine to the intercooler. I guess it is more of a collar.
In this Ebay picture, it is the short pipe coming off the top of the turbocharger.
https://www.ebay.ca/itm/144757775273
V70 2.4T High Idle after head gasket job
- Has thanked: 2210 times
Maestrours
- Year and Model: 03/2000 V70 XC 2.4T
- Has thanked: 29 times
- Been thanked: 9 times
Ahhhh sorry i was thinking about something smaller. Thanks i'll give it a look.
Maestrours
Idle is now ok since I changed injectors o-rings.
Always this smell on acceleration, just received my heat shield, i'll put it on the car and see if it change something.
If not, maybe ill need to give a look at the cat..
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Check for an exhaust leak. Sometimes if you're burning a bit of oil, it smells rather raunchy if it isn't going out the tailpipe away from you.
2023 Lexus RZ450e -66k
Good thinking wizechatmgr. Look for manifold leaks and particularly the flex pipe join.
Maestrours
Hello ! I put the heat shield on the car today. 100 miles after, no more smell ! Will not underestimate the power of those pieces anymore !
- 1310 Views
Last post by goldmandan
- 67 Replies
- 10421 Views
Last post by wizechatmgr
- 1316 Views
- 13 Replies
- 990 Views
Last post by Roger_850T
- 18 Replies
- 6383 Views
