And this mask fits in: https://www.amazon.com/dp/B016630UJU
Exhaust replacement - Cat/resonator flange rotted out
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Pick a dual voltage one. I've got a 110 v and it trips my breaker when welding thicker metal. Plasma cutter trips it in seconds. I was so annoyed that found another phase in garage and made a 240 v outlet. Now need to upgrade my welders (ARC and MIG).JayPea44 wrote: 28 Oct 2025, 08:24 A welder is definitely in my future. I just want to get this on right now. I've done a little migraine welding in the past so hopefully I remember the most of it and my FIL can give me some better tips.
A trip to Harbor Fright for a welder might come sooner rather than later.
I did see something like this which would work a lot better if/when I can weld it on
https://www.amazon.com/FGJQEFG-Hardware ... B0B8ZFHD4P
That other flanges pair looks like a proper fix to me.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
I only paid $300 for the machine, can't justify that much for very occasional use.vtl wrote: 28 Oct 2025, 06:01Need a better helmet? This one is freakin' awesome, I can see everything now: https://www.amazon.com/dp/B076H4MWDSjonesg wrote: 27 Oct 2025, 19:29 I had to buy a tank of argon/C25 gas as flux wire burns hotter and I couldn't see the weld joint.
vtl
I paid around that sum, too. Heck, my stick welder was under $100, and I still use it for bigger stuff, like log splitter. Helmet is so far the most important part in welding. It protects you, it lets you see what you're doing. I have two cheaper helmets, got tired of seeing nothing or getting flash burns. Think about it.jonesg wrote: 29 Oct 2025, 06:28 I only paid $300 for the machine, can't justify that much for very occasional use.
- jonesg
yikes, don't do it, their mig is way over priced.JayPea44 wrote: 28 Oct 2025, 08:24
Buyers like to say "I can always take it back", not so fast, theres a 18% restock fee. Only 90 day warranty, No stick gun, no alum spoolgun.
Primeweld 180 is the same price and comes with the spoolgun to mig alum and a stick gun for arc welding, dual voltage and stellar reputation for warranty and customer service, when they upgraded their machine they sent out free motherboards.
https://www.amazon.com/PrimeWeld-MIG180 ... NFPT&psc=1
- jonesg
Thats the way to go, having a welder opens up better options.JayPea44 wrote: 28 Oct 2025, 08:24
https://www.amazon.com/FGJQEFG-Hardware ... F0aWM&th=1
The Land Of Lincoln will make you a happy welder ….
Kristopher111
- Year and Model: 2019 Volvo V60 Cross
The situation hasn't changed much. Many budget exhausts still use catalytic converters with smaller reduction gears, so even if they don't immediately trigger a P0420 error, they often clean exhaust gases much worse than the stock unit. If emissions testing is important to you, I'd rather buy a good used stock exhaust or have the original catalytic converter professionally rebuilt than risk buying the cheapest aftermarket option. I use https://mostbet.net.in/ for the same reason. In a broader approach, this usually turns out to be a less problematic solution.vtl wrote: 27 Oct 2025, 10:57New OE DP costs exorbitant money. The affordable ones are made of thin cheap steel and cheap ceramic converter, which your rear oxygen sensor will dislike. I have a good quality 3" downpipe that has a cheaper converter, and the only reason I don't get a cat efficiency code is my ECM tune that ignores the downstream sensor altogether. But I can tell by smell that this aftermarket CAT is not anywhere near the expensive metal one that Volvo used.JayPea44 wrote: 27 Oct 2025, 10:52 This seems more expensive than just getting a new down pipe. My FIL is a welder, maybe I can ask him.
Bring a 6-pack to your FIL, welding an old car with a relative is a good bonding experience![]()
- Has thanked: 2199 times
- Been thanked: 1851 times
Here it you cannot buy used catalytic converters. The junkyard cut them out and recycle them so that is not an option.
Buying privately from someone parting a car out may be the only option for a used one.
Search the P80 pages for the company making cool SS flange kits in all sizes - the name is escaping me but it will return as my neurons slowly adjust to my home time zone
Bear River Converters maybe??
- 871 Views
Last post by Herb Goltz
- 3372 Views
Last post by DGB47
- 527 Views
- 361 Views
Last post by rjS60Turbo
- 616 Views
Last post by SuperHerman
