99 s70 cv boot replacement
Putting a Value on a T-5R
If you unbolt the A-arm or Control Arm at the subframe you don't have to mess with the ball joint at all. We tried this recently and it did prove to be the more painless method. Plus you don't tear up the boot on the ball joint this way.
Brucebo
- Year and Model: 850 '96, S70 '99
- Has thanked: 3 times
- Been thanked: 5 times
There is a very good post on this board, with pictures, on removing the engine. One subsection is on removing the axles. It shows, with pictures, the unbolting the Control Arm method you mention. Here is the post:j_cd wrote:If you unbolt the A-arm or Control Arm at the subframe you don't have to mess with the ball joint at all. We tried this recently and it did prove to be the more painless method. Plus you don't tear up the boot on the ball joint this way.
https://www.matthewsvolvosite.com/forums ... =1&t=28973
-Bruce
- 11 Replies
- 6084 Views
Last post by default
- 926 Views
Last post by CThompson
- 762 Views
Last post by boneman131
- 1681 Views
Last post by rocketman4321
- 3130 Views
Last post by foggydogg
