Front Suspension - Spring noise - 2001 V70 2.4T
- Has thanked: 17 times
- Been thanked: 35 times
Yes, it certainly could be the problem! I hope that the ball joint (control arm?) replacement takes care of it.
"ball joint"
I'm refering to the part joining the lower "A" arm to the "steering knuckle" (part #2745481. in VADIS).
Ordered the part through FCP Groton.
Will keep you informed if this is the fix.
2001 V70 2.4T - RIP
2011 S60 T6 AWD - In progress
2004 V40 - "backup"
2004 V40 - "backup"
Just different terminology- same part.
Changed the ball joints last night.
Front definitely more rigid/solid.
No spring noise so far.
Will give it a couple fo days to make sure though.
In the meantime, discovered that I had to replace the rear parking brake shoes while replacing the rear disks...
Notes
* Ball Joints from FCP were Scantech.
* Put me in a lukewarm mood considering the different reviews of this brand.
* Discussed situation with FCP. FCP guarantee them for 2 years.
* Considering the road quality in the province of Qu
Notes
2001 V70 2.4T - RIP
2004 V40 - "backup"
2004 V40 - "backup"
Based on your description of the sound (metal-on-rubber squeaky noise?) it makes me think that it's very likely to be a sway bar bushing, control arm bushing or ball joint. Try jacking the car one side at a time (to get the bar to twist a bit) with a floor jack, and while listening closely, let it down pretty quick. You SHOULD be able to duplicate your sound by doing this, it may take a few tries with the wheel turned this way or that. DON'T lube stuff ahead of time...you WANT to hear it so that you can isolate the noise and treat it permanently. Best of luck, let us know when you figure out what it is...
***EDIT*** Sorry man, somehow I completely missed your last post...glad you got it figured out!
Take care,
Ted
'04 V70 T5 Silver...the disease continues.
'98 V70 T5, Red ("Radio Flyer"), the original infection.
'95 Alfa 164LS
'82 Lancia Zagato
'74 Fiat 124 Spider
GMC Yukon "for truck stuff"
Ted
'95 Alfa 164LS
'82 Lancia Zagato
'74 Fiat 124 Spider
No problem.
Will remember the trick though.
Thanks
p.s. Noise is definitely gone. Hopefully, the scantech ball joints will last...
Thanks
2001 V70 2.4T - RIP
2004 V40 - "backup"
2004 V40 - "backup"
DieselDoNicely
- Year and Model:
I cant be the steering arm ball joint....can it......could be though especially if its dry inside.Harleyvh wrote:No problem.
Thanks
DDN
1997 850 Turbo Diesel Auto Estate (390,000 miles)
2003 V70 D5(turbo diesel) Auto Estate - Powerflex poly wishbone bushed
2005 V70 D5(turbo diesel) Geartronic Estate.
DieselDoNicely
- Year and Model:
Doh, bottom ball joint on the wishbone, the bolted on item. That sounds like it could be it.DieselDoNicely wrote:I cant be the steering arm ball joint....can it......could be though especially if its dry inside.Harleyvh wrote:No problem.
Thanks
DDN
If you dont get any more bedsprings, could you let us know after a good test, Ill then do the joints on my D5 V70 and post as to if it cures mine also.
Good on yer.
DDN
DDN
After month, Noise was mostly out.
Happening only in deep depression since the 24th... (merry christmas...)
Scantech lower ball joints defective?
I'm planning a visit at the garage in the next two weeks to replace worn out rear brake shoes.... so I'll have a look.
willl keep you posted.
in the meantime... Season's greetings
2001 V70 2.4T - RIP
2004 V40 - "backup"
2004 V40 - "backup"
