The tutorial is great, but I ran into a problem. My 2000 V70 has the rectangular coil, and does not have the nice thick single cable, but has several wires to each coil surrounded by a black plastic wire organizer. Unfortunately the wire organizer has degraded and breaks into small pieces at the lightest touch. So, I have factory installed 'crud' waiting to fall into the plug well and into the cylinder if the plug is out.
My approach, after noticing the bits, was to use a compressor to blow the crud off the top. Then for each plug blow out each well before removing the plug. Then carefully replace the plug. Also, after the first pass of blowing the crud off I noticed that the timing belt is exposed with the cover off, I was more careful after that. The plastic was so degraded that compressed air broke pieces off, there is very little remaining. It appeared that this was not a new problem. Last plug change was by a Volvo dealer, plug 4 had some corrosion like residue.
Status: after replacing the plugs and putting the covers back on the car started and ran well (for the 15 minutes I ran it).
Question: Any thoughts about the degraded wire organizers? Can I leave the wires loose? If replacing is necessary, any suggestions for better quality? They seem to be made from the same plastic as surround wire runs in the engine compartment. They plastic is just not up to the heat from contact with the engine block and no airflow under the cover.
My default is to leave it as is for now. Replace with new, automotive grade wire organizer in the near future. Buying new plug wires is not in the budget now.
Thanks, Paul
New How-To: Install Spark Plugs 850/S70/V70/C70
Spark Plug Change Tutorial: Volvo 850, S70, V70, XC70, C70
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Mine is all degraded too on my injector wires.
I would suggest getting some heat shrink tubing and putting it around the wire bundles.
'98 S70 T5
2016 Chevy Cruze Premier
KlubMarcus
- Year and Model: V70 XC, 1998
Some more pictures to supplemental earlier posts from a 1998 V70 XC spark plug change.
I found that using E3 spark plugs provided a better oomph for my V70 compared to the other brands and no need to gap. Also it gave me an indication of what kind of shape the engine would be in when I replaced them. Spark plugs are like teeth, if they aren't clean its gonna be some expensive specialist work to bring it up to a shine again.
Volvo V70 AWD 1998
Volvo V70 XC AWD 1999
Mercedes 300E, 386XXX, 1990
Do we need anti-seize lubricant? My spark plugs are long overdue and I don't have any anti-seize lubricants. I think I'm near 80k km on them. Have to double check to make sure.
2000 Volvo S70 SE; First Owner; 321km; Retired
2012 Volvo S60 T5 Level II; Gone
You can touch the threads to the dipstick to put a drop of oil in the threads and keep them from seizing up. Important if you are running the fancy plugs with 100,000 mile intervals
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Always use some kind of lube when steel threads into aluminum or you will get galling. Oil is better than nothing but will likely dry up or get burnt off. Invest in anti seize and use on all service bolts and you will save yourself lots of headaches. It works by leaving small pieces of nickel or copper on the threads
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Ringo
- Year and Model: 2006 70XC
- Has thanked: 33 times
How often do you folks replace your spark plugs if not experiencing misfires? Are there signs it's time?
What might do new plugs do for mileage or performance?
thanks, Steve
thanks, Steve
2006 XC70 2.5T auto (B5254T2) 125K 2nd owner
1999 V70 XC 2.4T auto (B5254T) 250K Trans failed 2018
1967 122S 2-door auto (B18B) 125K (ex-wife got it 1991)
I run Bosch copper plugs for 30k miles. I regap them at 15k. My turbo models usually need adjustment , my NA models do not. I get my replacememt plugs free from FCP
Ringo
thanks for the quick reply Abacate.
Regarding Bosch copper for a turbo are you just solidly old school or cheap like me? Or do you not think the OEM Platinum are no better? I have a turbo XC70. Also what gap do you set and does it change and get larger (or smaller) ? I intend on buying from FCP - because I'm cheap! (but also because FCP are great folks)
- 3286 Views
Last post by ndphotonl
- 11 Replies
- 568 Views
Last post by TJsPOV
- 4217 Views
- 1239 Views
Last post by Roger_850T
- 23 Replies
- 8215 Views
Last post by CooksD13
