Replacing CVVT Solenoid for Code P1332
This topic is in the MVS Volvo Repair Database » Replacing CVVT Solenoid for Code P1332
sweet2burs
Year and Model: 2002 s80
Post by sweet2burs »
hi I am getting ready to change my cvvt solenoid i ordered a used one on ebay of the exact match i did pull the part number before ordering to make sure and did look at the connector end .i have a 2002 volvo s80 will i need to have this programmed or can i simply just switch it out .since i will not have to cut any wires and also can i leave the battery hooked up again since i will only be unplugging this . i am asking this because the closest volvo dealership is over 2 hours from my location :( and no one in my area will touch a volvo ???? i need to know asap since my 89 gmc currently, i have had to remove my trany on that and wont have the replacement in for a bit :(
allenzachary
Year and Model: 2006 XC70
Post by allenzachary »
Disconnecting the battery is always the safest for you and the vehicle. But... I've changed these with the battery connected and never had an issue.
allenzachary
2006 XC70, 2002 XC70
MindOfVacuity
Year and Model: v70 1999
Post by MindOfVacuity »
Does anyone know what the bolts on the solenoid should be torqued to?
Has thanked: 1609 times
Been thanked: 4064 times
Torque 10 Nm crosswise
Jmast755
Year and Model: s80 t6 1999
Post by Jmast755 »
Hey is this applicable for a 1999 Volvo s80 T6? I have the same code coming up and I have emissions at the end of the month!
Nicknice33
Year and Model: 2000 volvo s80 t6
Post by Nicknice33 »
I'm getting code p1332 and p0013 I just bought a camshaft positioning sensor is this all I need and will it work
Probably not the problem nick. Try replacing the CVVT, clearing codes, and see what comes back
v-45magna
Year and Model: 99 S70 GLT
Has thanked: 2 times
Post by v-45magna »
Does anyone know if you can get just the wiring and female connector from Volvo? I've got a used one with the smaller connector to put on.
v-45magna
Post by v-45magna »
Can you get just the wire terminals and female connector/seals from anyone? Does anyone have an identifying number or name for this type of connector?
There was a good DIY on this and IM pretty sure the OP could not get the connector from Volvo - in fact he documented how to make sure you splice the right connectors into he OEM connector really well.
