SteveOV70 wrote: ↑08 Jun 2025, 09:17 Hey so with my Volvo V70, mine is the FWD and the code that was given to me was a 02059, somthing abou t whatever regulates the fuel. So I was told all that was apart of the fuel pump itself, I went and got a new fuel pump replaced it and it was super easy. But then a week later car would crank then just very slowly rev down sputter and bam dead. I took it to a garage cause by this point I needed a car to drive to work. They told me it was either the pump or the PEM. After pondering it I thought about it, because my model doesn’t have a regulator. So I thought.. well what tells my pump to work? To send whatever fuel it need to go?, well it would be the fuel PEM which controls all that! Batta bing! Problem solved! I haven’t had a single issue w the fuel since then. So I don’t know what codes those are you are getting but know that just cause a code tells u one thing doesn’t always mean it’s that. But I’m sure if those codes are fuel pump related I’m sure it’s your pump. If you need and help w what to do for replacing the pump holler at me I’m glad to help
Yeah I need help.
Hi
I am stuck.
Bought a snake puller for electrical wire.
Will try that tomorrow
Virginia , USA.
Allen
