just did a simple mod and WOW!
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
If that's the case, something else isn't letting it build boost. A broken hose, cracked intercooler, bad CBV valve, vacuum lines, etc. That gauge on an 850 should pin itself to the right under full throttle at ~4000 RPM, but it's just a guide if anything - not accurate at all.
Back it off and get a boost gauge before playing with it like that. You shouldn't be hitting full boost before 3000 RPM or more. The engine internals just can't handle it.
'98 S70 T5
2016 Chevy Cruze Premier
trophytaker308
Year and Model: 1995 850t turbo
Post by trophytaker308 »
set at 1.8-maybe a fuzz more.,and now that i think about it,it does go just a tad more,more like 3/4 at wot around 35-4 grand...i guess tomorrow i will put it back, i dont want to mess something up....oh well.
1995 850t turbo,siver with black leahter interior (perfect),, 118000 miles .second owner.9 out of a 10...!
trophytaker308
jblackburn wrote:If that's the case, something else isn't letting it build boost. A broken hose, cracked intercooler, bad CBV valve, vacuum lines, etc. That gauge on an 850 should pin itself to the right under full throttle at ~4000 RPM, but it's just a guide if anything - not accurate at all.
should it pin it back stock set up,or after i did what i done???
s70glt novice[Will]
Year and Model: s70 glt 98
Post by s70glt novice[Will] »
Stock. Like most of us have said, something isnt right. If you get a boost gauge, you can monitor vacuum at idle, which will help find the problem.
Don't turn it all the way back, do a little research and put it at stock (3.5 psi?). Then look around in the engine bay. Holes in inter-cooler lines, etc. Is your CEL on?
'98 s70 GLT-127k
ARD Green, obx, 16t, other go-fast parts
trophytaker308
i have no dash lights on and i sprayed statrer fluid all over the motor and it never died or raised rpms.....everone says it should be a fuzz over the white line fatory when at wot....
s70glt novice[Will]
trophytaker308 wrote: i sprayed statrer fluid all over the motor and it never died or raised rpms.....
Woah, wait, what? Explain more please...
'98 s70 GLT-127k
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
spraying starter fluid is a standard test for vacuum leaks. If there is a leak then the fluid will get sucked into the intake and burn, raising RPMs.
trophytaker308
i dosnt hit full boost untill bout 4 grand and its about 3/4 way to the end,but i have no other mods at all.
trophytaker308
im going to bed,ill catch back tomorrow,feel free to type and ill read it when i get up...later.
s70glt novice[Will]
Yes, something is preventing that. If you leave it where it is and fix the problem, and take it for a drive, very bad things will happen. So return it to stock, then investigate whats causing boost problems.
'98 s70 GLT-127k
