Idle/Power Problems? Troubleshoot Here
figmentj13
Year and Model: 2002 XC70
Post by figmentj13 »
My V70 FWD was dropping in RPMs, it would stutter and settle back to 950 when coming to a stop.
Stealership said clean throttle body, so I did.
Problem fixed. :D
So with any issues with idle or throttle it's best to get a $6 can of throttle cleaner FIRST and if that doesn't help you THEN suspect other things.
tags # s70 1999 2000
RIP: 2000 V70 SE <- Rear end while parked. :-(
Has thanked: 1612 times
Been thanked: 4075 times
m96ag wrote:For 1999+ cars cracked/bad coil packs can cause a lot of issues similar to those of a bad cap or wires.
The only trouble I had with mine was after a jump start pack (school bus type) which took out one of my coils on my 1999. Ignition wise, the Electronic throttle body system is pretty solid IMHO
tatsnturbos
Year and Model: 1998 Volvo S70 T5 SE
Post by tatsnturbos »
My 98 S70 T5 sputters whenever I press the brake, and someone suggested that it could be my injectors. Would injectors cause this issue?
figmentj13
@tatsnturbos are you moving when you press the break?
I did a lot of over thinking it and tried replacing the MAF....Didn't fix the problem and I didn't need to do it.
As i said above, before you go crazy replacing parts like I did take off the throttle body and clean it thuroly. I ended up using an old tooth brush and cotton swabs to clean it.
The throttle body needs to be cleaned every 50,000 anyway. If you don't know the last time it was cleaned do it for peace of mind.
echase76
Year and Model: 1998 v70 T5m
Post by echase76 »
tatsnturbos you may have a vacuum leak in your brake booster line. Do you ever have rough idle when sitting in gear with your foot on the brake?
1998 V70 T5m Silver/Charcoal - 150K
tatsnturbos
figmentj13 wrote:@tatsnturbos are you moving when you press the break?
Sorry, I'm very new to this, where is the throttle body... :oops:
Should've mentioned my car is an automatic, sorry. Yes, when in drive and brake is depressed, it rumbles pretty hard. When it's in park, it rumbles, but not as rough as when in drive with my foot on the brake. Also, its extremly slow to accelerate.
tatsnturbos
Also forgot to mention he unplugged my MAF, he mumbles alot and I dont really know why he did this, but he said to keep it unplugged until we diagnose the problem.
echase76
Post by echase76 »
Sounds like a brake booster vacuum leak to me.
The search function on this site and the repair database button are your friends.
Here is one tutorial to get you oriented on the TB. Ignore the EGR
https://www.matthewsvolvosite.com/forums ... =1&t=44933
tatsnturbos
Thanks echase76!
Also, does anyone have a diagram of the vacuum lines to the brake booster? I found a vacuum line diagram on here but it didnt include the brake booster.
echase76
Post by echase76 »
I don't have a diagram, but it runs from under the TB then under the Airfilter box, I believe under the steering column and then up to the brake booster. This is from memory so I might be a bit off. I think it is about 1/2" OD line.
You may want to start a new thread for your issues. It will get more looks and probably more responses.
