VIDA and DICE issues
mf70
Year and Model: V50 2006
Been thanked: 2 times
Post by mf70 »
On the basis of the single install I have done (grin), I'm pretty sure you need to have matching firmware in the DiCE to go with the version of VIDA you are running.
I did the firmware refresh away from the car by providing 12V power through the OBD2 connector. It went smoothly.
mrscullini
Year and Model: 05 XC70, 08 XC70
Has thanked: 1 time
Post by mrscullini »
just got my dice unit and having similar issues to those described here. vida recognizes the dice unit but i'm not able to interface with the car. i'm running fw 5.6.2, is this an issue? i'm also running the 2012b image on vmware. please help.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Get Windows on a bare metal hardware, not VM.
mrscullini
Has thanked: 1 time
vtl wrote:Get Windows on a bare metal hardware, not VM.
is that my best hope? are most running xp sp3 on a dedicated machine? i got vida 2013A with my dice unit.
so the fw is OK?
vtl
Post by vtl »
mrscullini wrote:is that my best hope?
Yeah, your host OS or hypervisor can't do a fully transparent USB bypass to a virtual machine.
I run 2011C on a 32-bit XP SP3. It also worked on a 64-bit Win7, but was crashing too often.
so the fw is OK?
Firmware is ok.
mrscullini
Has thanked: 1 time
so the fw is OK?
Firmware is ok.
great, thanks! i figured a dedicated machine may always be needed.
just as an fyi, my host machine is a win7 home premium.
another question, memory and cpu requirements? i new at least a couple gigs on memory. any specific cpu specs?
vtl
Post by vtl »
If you laptop is able to run Win7, it's capable of running VIDA. Mine is 4 years old Lenovo IdeaPad y460p (SandyBridge i7-2630QM, 8GB RAM). But you need at least Win7 Professional (or fool VIDA's installer, google around).
Liliflower
Year and Model: Volvo S60 2005
Post by Liliflower »
be careful about the ebay or aliexpress VIDA unit with only blue indicator flashes, the working DiCE unit is with colorful indicators (illuminates when good communication is built)
AS for the operating system, old VIDA (2012 A-D, 2013 A-D or before) should be installed on win xp or win 7 VMware, 2013A-D, 2014 A-D (current VIDA 2014D) can be loaded ok on Win 7 professional IE8, no win xp
2014A VIDA installation video:
2014D VIDA installation video:
For who meets VIDA NOT OK error, here is the document i googled, not sure if it works
http://blog.uobd2.net/uobd2-engineer-fi ... r-message/
keng
Year and Model: S60 T5 2005
Post by keng »
Windows 7 ultimate, 2014D.
Interface test not ok. Exactly same problem like above.
My dice used to work well with VIDA & Vdash for many years. It stop work recently without reason. Both VIDA & Vdash cannot read my 2 Volvo.
I did uninstall& reinstall the dice and update the firmware again, 5.6.2, however, problem persist.
Please advise what I can do further.
lrock
Year and Model: 2001 v70 xc
Has thanked: 9 times
Been thanked: 37 times
Post by lrock »
keng wrote: 27 Dec 2025, 18:04 Windows 7 ultimate, 2014D.
if you have $5 to spare, try using one of the w10 VMs at volvodiag.com using either vmware or virtual box.
just remember to forward the dice units usb port to the vm.
