1998 s70 will not run
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
Bob on number 13, do you mean the engine turns over regular-fast, or turns over maybe-faster-than-normal?
If it is faster than normal, try a teaspoon of oil in each cylinder. Search here for "lawn mower syndrome."
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Alternatively to Erik's suggestion as the compression numbers are fine if you remove say 2 spark plugs does the engine spin faster or the same? The reason I would try this first is oil in the chamber has a habit of fouling plugs superfast. Also which plugs and type did you use?
mercuric
Year and Model: 1997 850 T5
Been thanked: 2 times
Post by mercuric »
So it seems you get spark, good. You have fuel pressure. Good. Other neat stuff in order. Good.
The one thing that remains to be answered, in terms of initial diagnostics: Are you getting injector pulses? Fuel pressure is important, but without injector pulses, that fuel is going nowhere.
Best way to verify this is with a noid light. like: https://www.amazon.com/Alltrade-940580-F ... B0028QGU6C -- you can probably obtain one from a local parts shop, or build one -- it's really just an LED and current limiting resistor (anything in the 1-5kohm range should be fine)
What it looks like:
If you're not getting pulses, that sends us down another path of diagnosis...
boballen
Year and Model: 1998 S70
Post by boballen »
Eric And Precopster, It occurred to me that maybe the spark plugs were not the right ones. i got the volvo from an estate sale and these plugs were new in a box that came with the car. I assumed they were the right ones. The plugs are Bosch Platium Fusion #4503. I went with Erics suggestion before I got Precopster's. Plugs can be cleaned. It did seem to make a difference. The car actually fired a couple of times but still failed to start.
Bob
boballen
Post by boballen »
Mercuric, If the plugs are wet and smell of gas, does this indicate I am getting injection pluse?
Bob
mercuric
Post by mercuric »
yack, the 4503s are the multi-tip plugs, those tend to produce bad results, but questionable if they'd result in a complete no start even after a cleaning. Either way, some single-prong copper-tip plugs are the way to go... like the old days :)
mercuric
Post by mercuric »
boballen wrote:Mercuric, If the plugs are wet and smell of gas, does this indicate I am getting injection pluse?
Bob
Most likely :)
Darn, I was hoping it was just the main injection relay or some simple electrical stuff :lol:
Post by erikv11 »
precopster wrote:Alternatively to Erik's suggestion as the compression numbers are fine if you remove say 2 spark plugs does the engine spin faster or the same? The reason I would try this first is oil in the chamber has a habit of fouling plugs superfast. Also which plugs and type did you use?
He's totally right, if those cylinders have compression then disregard my idea.
You've replaced a lot of stuff, it might be worth getting standard copper plugs and dropping them in there, they are only like $1.50 each. The 4503s are indeed terrible for these cars, but can they really be this bad? But I am still stumped.
You have the firing order correct I don't suppose you got the rotation direction wrong? This is the correct placement of wires:
http://volvospeed.com/volvo_repairs_how ... plugs.html
precopster
I think I have heard of cars that won't start with:
a) A faulty throttle position sensor
b) A faulty temperature sensor on the thermostat housing
Both components lead to excessive fuel entering the combustion chamber and causing flooding. You probably can already smell unburned fuel so the only way to get around this is to try the new plugs then move on to the other components I mentioned.
Has thanked: 1614 times
Been thanked: 4078 times
It's a lot of work but you could remove each plug and put starting fluid in each cylinder
Starting fluid is di-ethyl ether. If it won't fire on this for a few seconds, you don't have spark at the right time in any cylinder
At least one shop manual has firing order of Volvo wrong btw.
