Anyone replaced the seal on the automatic transmission dipstick pipe (lower)? The connection between the dipstick tube and the transmission? Is it the same seal like the one on the engine dipstick tube?
Here is some link: https://www.ipdusa.com/products/20906/1 ... 8-30637865
DIY: 1998 S70 GLT Trans Cooler Line Rebuild for $10!
- Has thanked: 312 times
- Been thanked: 818 times
Yep, the oil dipstick tube and the transmission dipstick tube use the same sealing ring.
I would spend up on this seal, shell out the $5 for a factory one (e.g. https://www.fcpeuro.com/products/volvo- ... 30637865oe or IPD probably sells them too).
luckykolo
- Year and Model: s70 1998 Base
- Has thanked: 14 times
I was trying to remove the automatic transmission dipstick tube in order to have more access to the lower starter bolt. I was able to turn the dipstick pipe around but I was not able to remove it. I unbolted dipstick's bracket (from harness and PNP). Stuck solid. Is there a secret to it? I was planning to replace the seal for the dipstick tube, but damn pipe does not budge. It moved upward just tiny bit. I thought that it's similar to the engine oil dipstick pipe...
Thanks
Thanks
- 11 Replies
- 6679 Views
Last post by foggydogg
- 2118 Views
- 2069 Views
Last post by shiloh51933
- 32 Replies
- 17904 Views
Last post by sleddriver
- 1249 Views
Last post by BackRoadSeeker
