I'm still not fully convinced it's the regulator.
Can you start the engine and then quickly disconnect the positive terminal with the engine running? Take measurements at the positive leads and see if voltage still climbs. If not your culprit is the battery.
2000 V70-XC dash lights for ABS traction control on
precopster
- Year and Model: Lots
- Been thanked: 128 times
- cmblackburn
- Year and Model: 1998 S70 T5M
- Has thanked: 1 time
- Been thanked: 7 times
Bad abs module. Never heard of the battery smoking... That's kinda scary. I'd do a parasitic draw test and find out what's drawing so much power and yank it's fuse.
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
- cmblackburn
Pulling the positive on these newer cars is really harsh to the ECU's. You don't wanna fry a vin-tagged 99+ ecu... That'll be pretty expensive to take care of.
precopster
The voltage is 17V at the terminals. If something were drawimg current from the battery the voltage would be far lower.
Lesson 101 here is V=IR
Yanking the positive allows the alternator to solely supply voltage to the car's electrical system; nothing wrong with that as long as the power is clean and without AC content.
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
His abs module is likely fine, it will shut down on its own and trigger codes if the voltage is too low or too high. In any strange voltage situation it's the first thing to take a break.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- 1731 Views
Last post by CDoore54
- 2328 Views
- 288 Views
Last post by jonesg
- 1248 Views
- 954 Views
Last post by bmdubya1198
