2005 xc70 drive shaft replacement?
mrscullini
Year and Model: 05 XC70, 08 XC70
Has thanked: 1 time
Post by mrscullini »
JRL wrote:You just don't want to listen to me, do you?
GLUE THE FRIGGEN BOLTS
They all start to do this over time. The splines become worn and the play becomes bigger, hence the louder noises
i am listening. i have new bolts being delivered tomorrow. i'll report back.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Visual image of steam being vented all of a sudden by a pressure cooker. :mrgreen:
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Seriously, I just went through this on mine and have done several others. If it doesn't get rid of the clicks completely, the noises should be seriously reduced and be liveable.
mrscullini
Has thanked: 1 time
JRL wrote:Seriously, I just went through this on mine and have done several others. If it doesn't get rid of the clicks completely, the noises should be seriously reduced and be liveable.
thanks jrl. i don't doubt your knowledge. hopefully i will be replacing on friday.
battling a new issue, please see my latest post and weigh in.
mrscullini
Has thanked: 1 time
axle bolts arrived today. can i replace with the car on the ground, wheels loaded? just simply take out the old and install the new?
JRL
Post by JRL »
Do not overtighten.
I just heard of a couple of guys snapping these bolts.
Use the correct torque spec
mrscullini
Has thanked: 1 time
JRL wrote:Do not overtighten.
thanks. i read of a couple guys doing the same. i have a torque wrench and angle gauge.
is it ok to replace with the car on the ground?
mrscullini
Has thanked: 1 time
new axle bolts in. i used loctite and the correct torque spec. i also let them sit over night. the clicking is the same. where else should i look? can i rule out the drive shaft and assume it is related to the axles? is it ok to leave it as is for now or is it the precursor for a major failure?
gingerman
Year and Model: 04 xc70
Post by gingerman »
mrscullini, I am having a similar issue, did this fix it for you?
