P80 cordless Bosch lug nut tool 125 or 500 ft lb version?
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Excellent! Having a good driver option, air or electric, makes those never ending wheel swaps much zippier.
Has thanked: 1609 times
Been thanked: 4064 times
The best addition to this tool has been the flexible extension which lets me run down all sorts of fasteners in awkward places. This saves a lot of hand work.
Mstrshkbrnnn
Year and Model: 94 850
Been thanked: 2 times
Post by Mstrshkbrnnn »
I've got a milwaukee fuel m18 impact DRIVER and it can break almost any lug nut loose. The only issue is that the little adapters that allow you to put on sockets break.
'94 854 NA 287k (bought for $400)
'98 s70 GLT 243k (bought for $250 currently non running)
'96 854R 173K (bought for $900)
'88 245 DL who knows (bought for $600)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
If you're going to buy one of these 18v impact drivers, and choose Amazon to buy it from, use this 18v impact drivers link and it helps MVS. Thanks in advance.
Also -> Amazon link
Has thanked: 2197 times
Been thanked: 1851 times
I still use the 2 impact drivers mentioned earlier. However, I had the case when some numb-nuts at Kia dealer used an impact driver on the boss's Kia Sportage. 350 ft/lb corded driver would not budge them. Out came the 3/4" x 48" long break-bar! Nuts should have only been 80 ft/lb MAX on that car!!
Post by erikv11 »
OK, for the record then: Still have never come across an axle nut or lug nut that my cheap HF corded impact did not break loose. Knock on wood.
erikv11 wrote: 05 Sep 2019, 18:07 OK, for the record then: Still have never come across an axle nut or lug nut that my cheap HF corded impact did not break loose. Knock on wood.
I think I can say the same , but’s i don’t like rattling for more than a few seconds. Too loud. After about 6 seconds, I break out the 18 inch cheater and off they come, quietly.
Where do I get some of those Iowa front wheel bearings? My right front is going again...
FCP BABY!
