07 S60 2.5t code P0027 [ Bad quality aftermarket vvvt solenoid]
Idamon
- Year and Model: ‘07 S60T, ‘88 745GLE
FINALLY solved this problem. I took the car to a Volvo specialist shop where they took a look at it with VIDA. Confirmed to be an intermittent problem with the exhaust VVT caused by a bad VVT hub, bad solenoid or wiring fault. They couldn’t narrow it down any further. So I ordered a new hub and installed it. Fault came up again within 5 minutes of driving. Decided the only way to check the solenoid wiring was to go right back to the ECU box. I found a good wiring diagram, determined the correct pins on the module connector socket. With 12v on one side of the solenoid, I grounded the appropriate terminal on the ECU socket and the solenoid worked. I checked the intake solenoid in the same manner. The only other culprit was the solenoid itself which I had already replaced with a new (but aftermarket) unit. I got hold of yet another used one, installed it, and low and behold the problem is fixed, no more P0027! All together it cost me over $700 in parts, but I saved that much on labour by doing it myself, which I couldn't have done without all the help from everyone here. THANK YOU all!
1988 745 GLE, 350k KM/217k miles, one owner (me)
2007 S60 2.5T, 198k KM/123k miles
- Been thanked: 4064 times
Let’s name the manufacturer of he part and Put them on the wall of shame
Idamon
Professional Parts Sweden is the manufacturer- as you correctly pointed out in a post earlier in this thread:abscate wrote: 02 Jun 2019, 02:58 Let’s name the manufacturer of he part and Put them on the wall of shame
“That's an aftermarket replacement part and quality of most of those are suspect.”
That’s why crappy parts supply chain is such a pain. You just can’t get a decent diagnosis without playing parts darts
- 8400 Views
Last post by RickHaleParker
- 2784 Views
- 12 Replies
- 5112 Views
Last post by mrbrian200
- 1337 Views
Last post by JIMMYCNOTES
- 2228 Views
Last post by SuperHerman
