Need help with strange issue
Has thanked: 1614 times
Been thanked: 4078 times
You’ve got a ton of Volvo dealers in Boston and they are competitiveness on parts. I would sort it out at partscounter and compare old And new
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
potiusmori wrote: 16 May 2019, 19:02 So im having an issue with ordering the lower right mount. One says chassis# up to 540000 and the other says up to 566xxx. The chassis # is the last 6 of the vin and mine is 767xxx. So which one do i buy?
The “lower right”? So the one towards the rear of the car? Or do you need the mount on the front of the engine, which is on the right side of the car?
If it’s the latter, there are two pretty distinct versions - you can distinguish them by sight. Take a look at which one is on there now, and buy the same one. :)
- S
[Sold] '97 S70 T5
Best to use part numbers to describe these, an “ MVS BEST PRACTICE” (tm)
Volvo uses car reference to locate engine mounts rather than engine reference, so the mount near the passenger side under the crank pulley is the “ right mount”
See 9180961
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
It's great that you figured it out. But as soon as I read your description I immediately thought it was upper and lower torque mounts. They keep the engine from shuddering and moving back and forth during driving and gear engagement. In an automatic transmission the vibration is much worse than in manual transmissions. These mounts also help keep the drive shafts and alignment. So when they go and you replace them it's time for an alignment.
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
Clemens
Has thanked: 501 times
Been thanked: 228 times
Post by Clemens »
@callahanoffroad: what kind of alignment? camber and toe or are you talking about driveshaft-alignment (whatever that would be)?
1996 855 R,
2010 V70 D5,
potiusmori
Year and Model: 850R 1997
Has thanked: 5 times
Been thanked: 2 times
Post by potiusmori »
Hey guys so just checking in. All 5 mounts came in today. Tried every dealer in 125mi radius and none had all of em in stock. So was fonna drive the 2h45m to fcp but they didnt have em in stock. Finally called ipd last (due to distance and no other reason) and they had all of em in stock. 2 are poly but thats ok. Will be changing em tomorrow and will update. Thank you all
potiusmori
On a side note a buddy from ipd told me he has a complete m66 swap all boxed up waiting to send me if i want it. Has everything for 00 v70. Trans(75k) clutch,cylinder,flywheel, shifter linkages and even console accent. Only asking 400+ship
manovlov
Has thanked: 675 times
Been thanked: 164 times
Post by manovlov »
potiusmori wrote: 15 May 2019, 19:33 Feels constant...
Speed doesnt seem to change the shudder that much and every gear shifts smoothly
To me, it sounds like mount (s) over (one or more).
Nice car by the way.
Manov - creature alive maker
potiusmori
Ok so not the update i was hoping. Got the 5 mounts. 3 of them fit perfect and were right. So changed the upper torque mount. The transmission torque rod/mount and the lower rear middle one (the bulb looking one). Unfortunately according to ipd and fcp and every dealer i have called my vin tells em beyond a doubt that my car came with a awd tranny. Well i was under there for a few hours today and i have fwd and it didnt even look as if i had a groove for the driveshaft to be awd. I dont see how a driveshaft would even fit under...So that being said the front lower middle mount which looks like the rear(bulb) didnt get changed due to being sent the adjustable V shaped one made for all awd's. So here is an interesting thing though. The mount behind the front passenger tire...past owner replaced it with a uro parts one made for a fwd. I recieved the one for layer chassis awd. Both mounts seem to fit the same only difference is awd looks a little different and has aluminum spacer i didn't use. At this point i cant even tell if i have the aw50-42 or aw55...
potiusmori
Ok so have made good progress today. First the awd/fwd vin issue: i did have awd with the different exhaust then seems theres been a fwd tranny change in my car. This is assuming theres a different exhaust setup for both options cause a driveshaft wont fit were the exhaust is now. That being said means the awd front lower mount behind passenger side is correct one cause it mounts to engine even though tranny was changed. Got all other mounts done including picking up the bulb type one for front instead of adjustable awd one i ordered. Front and rear lower werent too bad and both were oem but still changed em. Pita!. Anyway started it up and the vibrations/shaking in D are about 30% less. Dash still rattles something fierce due to it being changed . Finally i narrowed my trans down to being a 5sp fwd aw55. I figured it was a 5 speed after trying to find anyway to tell the 4sp and 5sp apart in car and finding the only identifying difference. The dipstick and tube! The 4sp has the rounded top dipstick with just a straight tube were as the 5sp has the flat top dipstick and the tube has the metal lever that holds the dipstick in.
