1998 V70 AWD bad rear wheel bearing
bronco
Year and Model: 1998 V70
Has thanked: 49 times
Been thanked: 24 times
Post by bronco »
abscate wrote: 06 Jul 2020, 14:05 This is not as crazy as it sounds but you might be able to get some guidance on drilling a hole into the case and pumping oil in
Have you tried heating the plug with propane ?
It feels like the gas tank is a bit close for flame heating . I have thought about it though. I have torches I used them to burn the drivers side bearing off. I feel like the gas tank being right there is what stopped me from torching the axle shafts last fall.
You may be right though The gears don't do anything back there and isn't the housing aluminum? I suppose I could drill a hole shoot lube in and plug the hole with literally anything and it would be better than what is going on now.
Has thanked: 1609 times
Been thanked: 4063 times
You can keep heat localized to within a few cm of the flame and use wood to shield the tank. If it doesn’t char you are fine.
Drill, oil, and bung is actually in some cars’ official procedure manual.
