MoVolvos wrote: 09 Nov 2019, 19:12Mine is set up a little differently - there is the larger hose on top but nothing on the back of the PTC itself as in the diagram.cfelberg wrote: 09 Nov 2019, 19:02Scroll down and see the PTC diagram. It shows a large and small vacuum line. I believe the small one was clogged on mine. It's been awhile.MoVolvos wrote: 09 Nov 2019, 18:53
There is just one hose that goes directly to the top of the PTC and it is the hose from that long 90 degree hose assembly from the breather box. There are a couple of small vacuum lines that enter the turbo intake tube very near the PTC on their own nipples, but not connected to the PTC directly. Are these the ones you are thinking of?
http://lakesidedp.com/uploadpics/pcv/
2002 volvo s60 2.4t PCV still blocked after service/replacement
cfelberg
- Year and Model: 2002 s60
- Has thanked: 2 times
- Been thanked: 3 times
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
I see a bump. Has that been closed off on your car?cfelberg wrote: 09 Nov 2019, 19:43Mine is set up a little differently - there is the larger hose on top but nothing on the back of the PTC itself as in the diagram.MoVolvos wrote: 09 Nov 2019, 19:12
https://www.fcpeuro.com/products/volvo- ... 46#fitment
cfelberg
I believe so - I saw the bump you are referring to but there was nothing on it.MoVolvos wrote: 09 Nov 2019, 20:09I see a bump. Has that been closed off on your car?cfelberg wrote: 09 Nov 2019, 19:43Mine is set up a little differently - there is the larger hose on top but nothing on the back of the PTC itself as in the diagram.MoVolvos wrote: 09 Nov 2019, 19:12
- MoVolvos
Sorry, I think they did do away with that fitting there.cfelberg wrote: 09 Nov 2019, 20:14I believe so - I saw the bump you are referring to but there was nothing on it.MoVolvos wrote: 09 Nov 2019, 20:09I see a bump. Has that been closed off on your car?cfelberg wrote: 09 Nov 2019, 19:43
- MoVolvos
Can you see if the 2.5T is the same and if you may have missed something?cfelberg wrote: 09 Nov 2019, 08:29I feel I completed the job correctly but am not sure what to look at next if in fact this is a problem.93SCMax wrote: 09 Nov 2019, 08:00 I've never heard of a "PCV Glove Test" under load, only familiar with the glove test on the oil fill at idle. Are you seeing any new oil leaks on the engine?
If you are confident that you replaced the system correctly, I'd carry on as if it's repaired and only monitor for new leaks.
- MoVolvos
Here is another.
cfelberg
Yes, it is very similar - the fuel rail is a little different but the process was the same on mine, and all associated fittings and hoses for the breather box were the same - it doesn't appear I have missed anything on these components, thanks!MoVolvos wrote: 09 Nov 2019, 20:35Can you see if the 2.5T is the same and if you may have missed something?cfelberg wrote: 09 Nov 2019, 08:29I feel I completed the job correctly but am not sure what to look at next if in fact this is a problem.93SCMax wrote: 09 Nov 2019, 08:00 I've never heard of a "PCV Glove Test" under load, only familiar with the glove test on the oil fill at idle. Are you seeing any new oil leaks on the engine?
- MoVolvos
Could there be a vacuum leak and have no codes? When you are accelerating maybe a cracked / loose hose or leak somewhere is bringing air into the intake manifold rather than removing it from the crankcase.
cfelberg
Its worth a shot - I'll have to give it a try, thanks!MoVolvos wrote: 09 Nov 2019, 21:09 Could there be a vacuum leak and have no codes? When you are accelerating maybe a cracked / loose hose or leak somewhere is bringing air into the intake manifold rather than removing it from the crankcase.
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
VTL & a few others have posted about this before - glove testing at varying RPM’s & loads. I know he is a firm believer in replacing the expensive pipe that runs from the top of the breather box/oil trap back to the turbo. I personally have only done 4-5 of the PCV system’s & I've never replaced that upper ($175) pipe. I’ve always just checked it to verify it isn’t blocked down near the nipple & none I’ve encountered have been so have always just replaced the nipple & have never had an issue. I’m in no way saying he’s wrong (because he rarely is), just that it could be a possibility.
Pretty much any turbo gasser is gonna have blow by, but I’d think that would be more than normal in your case, if blow by is the culprit.
Did you drop your oil pan at all?
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- 2860 Views
- 24 Replies
- 9372 Views
- 30 Replies
- 9212 Views
Last post by Ben850
- 1382 Views
Last post by precopster
- 1197 Views
Last post by Nismou20
