As I had taken photos of the camshaft ends before I took off the cover, and then after I took the cover off, I was able to situate all the components to the positions they were in when I turned off the motor. From there I was able to align the crankshaft and both ends of the camshafts, so the correct timing was established. After the two revolutions of the crankshaft, the tensioner was addressed, but not without error, re-tries, minor adjustments, etc...(the nature of my skill and the beast) over the last three days!
Yesterday afternoon I began to res-assemble all the other components I removed to be able to extract the cam cover. Am almost done with that process and added coolant before the rain came. Today, I'll add some oil, secure the upper motor mount bracket (still need to extract from the engine the threaded part of the bolt after the top part sheared off as I removed the bracket - any suggestions?), connect the battery, and cross my fingers when I turn the key. I'll keep you all posted!!
Thanks again abscate, FLX90, and RickHaleParker for all your help!!
