yeah, i got that. i'm trying to figure out what the bad thing is.abscate wrote: 17 Oct 2020, 04:44 140 psi is fine for turbo wear spec is 125 psi or so.
Skip the tune until you get this other stuff sorted out. It won’t fix bad things
00 S70 GLT SE woes
fresh70
- Year and Model: 2000 S70 GLT SE
- Has thanked: 5 times
fresh70
Back with an update. Feel like an idiot, but the connectors for coils 1 and 2 were flipped. I'm not sure how it happened. I re-loomed everything and the wires were "permanently" curved to where they would only go in that orientation so I assumed they had to be correct. The wire lengths don't exactly make sense either; coil one should have a longer lead than coil two.
Anyway, the problem is solved. Runs perfect now.
Thanks to everyone who tried to help.
- Has thanked: 1611 times
- Been thanked: 4072 times
Every coil on plug Volvo owner eventually writes 1-5 on their coils in sharpie
- Has thanked: 2209 times
Well done figuring it out and admitting to making an error. It happens to all of us but most won't admit to it! LoL!!
Glad all seems good now and hopefully stays that way.
fresh70
I definitely have them labeled... problem was I took all the connectors off to re-loom them because I was prettying up the engine bay while everything was apart and somehow I managed to flip two of them. Still not entirely sure how the wires looked to be the perfect length and bend for 1&2, but were supposed to be 2&1. At any rate, it's done.
Now to put the new wastegate on and tune... the journey never ends.
Glad it is sorted! Good luck with the new adventures!
- 830 Views
Last post by erikv11
- 642 Views
Last post by theWIFES_S70
- 2220 Views
Last post by tryingbe
- 4140 Views
Last post by ryvsdiewelt
- 2439 Views
Last post by jmorman
