I just got a used abs tracs unit off a 98 S70 from a junk yard, $65 not a bad deal. Since i was having the abs tracs issue like most of you i swapped the units, after I installed the junk yard version the abs light is still on but the tracs light is gone. everytime i press the tracs button the light should come on and then off when i press it again, but no. Everytime i press the tracs button it just lights up for as long as Im holding it and then goes away. I did take it for a nice 8 mile drive nothing changes and no pump noises either. Could that mean the unit is defective and/or that the S70 they pulled it off of did not have the traction control option?
Thanks.
Do it yourself ABS module repair. Topic is solved
Do It Yourself ABS Module Repair
altamishS70
- Year and Model: S70 BASE, 1998
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
If the JY unit has 9162675 or 9140774, then it's a TRACS unit. If it has 9140773, it's non-tracs.
Most of the JY units I've bought to rebuild were already shot. Double check your harness though to make sure it's 100% seated. Odd combinations of lights instead of the standard ABS/TRACS lights being on sometimes point to the harness.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
C@lvin
- Year and Model:
- Been thanked: 2 times
I pulled spare ($40 at a pick and pull) off of a 99 S70. It has 9472650 on it. It also says "CONTROL-UNIT ABS/TRACS" just above the bar code. If you pull it yourself you can also see if there is a Tracs button on the dash.
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
98 S70
00 V70
Matty Moo
9472650 is an all-wheel-drive module.
IF your car is FWD, did it work in there?
2000 s70 GLT
2014 Ram
altamishS70
looks like the part they gave me was 9140773 which is for FWD w/o TRACS and mine has TRACS.
Matty Moo
Not gonna work. PM me if you want to do a trade.
2000 s70 GLT
2014 Ram
C@lvin
- Year and Model:
Matty Moo wrote:9472650 is an all-wheel-drive module.
In fact, the controller did not work in my 98 S70 (FWD), but I just assumed that it needed repair just like thousands of others.
I was in the middle of trying to repair my own and bought it as a spare in case I botched up my repair (I can't seem to solder worth a hoot, especially when I need new bifocals and I am trying to hold the solder, the soldering iron, the PCB, a magnifying glass and a bright light all with only two hands
Calvin
98 S70
00 V70
98 S70
00 V70
altamishS70
my original unit is a 9162675 and the unit another JY has is a 9140774, would that work in my vehicle?
Matty Moo
Yes, they are both the same module, just different part numbers.
2000 s70 GLT
2014 Ram
Matty Moo
The 9472650 is a 99 and up module. The 96-98's use a different module, that's why it wouldn't work.C@lvin wrote:Matty Moo wrote:9472650 is an all-wheel-drive module.
IF your car is FWD, did it work in there?I didn't think it was an AWD S70, now I am curious to go back and take another look at the donor car.
I was in the middle of trying to repair my own and bought it as a spare in case I botched up my repair (I can't seem to solder worth a hoot, especially when I need new bifocals and I am trying to hold the solder, the soldering iron, the PCB, a magnifying glass and a bright light all with only two hands)
96-98 TRACS is 9162675 or 9140774.
96-98 non-tracs is 9140773
2000 s70 GLT
2014 Ram
