Vida CEM swapping
oscilloscope
- Year and Model: 2005
- Has thanked: 27 times
- Been thanked: 11 times
hmmm well thats not good news , this CEM has had some action on the EEPROM so maybe someone else has been at it and caused some sort of damage to it. i have another CEM i might play about with and see if that works. && i also have another one!, ll coming as i just Won it on eBay. lots and lots of testing and messing around!
oscilloscope
Is it best to use the bosch ones ? , there not available over here in the uk anymore. It looks like they've been obsolete for some time , although I agree there available via ebay.usRickHaleParker wrote: 12 Oct 2022, 13:02The video was made way back in the beginning of all this. The x0 prefix was removed in later versions of the code.oscilloscope wrote: 12 Oct 2022, 01:46 Is the video vtl posted up an old video? So now the cracker does it differently now ?
Lots of SN65HVD230D chips and assembled SN65HVD230D CAN transceiver circuits on eBay.
A eBay vendor in Edinburg, Texas has lots of Bosch CF160.
oscilloscope
I made a purchase for the CF160s from the states on ebay.usRickHaleParker wrote: 12 Oct 2022, 13:02The video was made way back in the beginning of all this. The x0 prefix was removed in later versions of the code.oscilloscope wrote: 12 Oct 2022, 01:46 Is the video vtl posted up an old video? So now the cracker does it differently now ?
- RickHaleParker
- Been thanked: 979 times
You could get you one of them ready made PCBs for the CF160s and a J2534 / ISO 15765 ( OBD2 ) cable. That would eliminate a lot of physical build issues.
BTW: the CF160 version is one of my designs. There are a couple of people that designed PCBs for it. One of the MVS members made a batch of them, I don't recall who. Perhaps they will chime in and offer to sell you one.
Note: Pin one is not marked on the CF160s. The beveled edge is the key to determining which side is pin 1 - 4. You can figure this out from the CF160 datasheet.
Active
Past
Past
oscilloscope
RickHaleParker wrote: 14 Oct 2022, 03:52You could get you one of them ready made PCBs for the CF160s and a J2534 / ISO 15765 ( OBD2 ) cable. That would eliminate a lot of physical build issues.
The small parts I previously mentioned turned up (typical)
I placed an order afew days ago via pcbway which said it was part of this cem cracker. I'll have alook again what version of the transceiver it is.
I have also purchased a blank obd port & I'll use some Ethernet wire as that's twisted pair.
oscilloscope
I tested the cem cracker on it , but it didn't work very well although further testing is coming
I have instead gone down the route of coping the microcontroller. M32c
If I where to copy the m32c on board microcontroller to another one I have with the same part number would I need to perform a checksum on the data before I copy it over to the other one ?
oscilloscope
No worries , I'll certainly do that. , does the microcontroller need a checksum performing in it if its a straight copy over?
ZRimaZ
- Year and Model: XC60 MY2016 3.0 T6
- Has thanked: 23 times
- Been thanked: 13 times
No, just copy/pasteoscilloscope wrote: 18 Oct 2022, 06:46No worries , I'll certainly do that. , does the microcontroller need a checksum performing in it if its a straight copy over?
Have a nice day,
ZRimaZ
ZRimaZ
oscilloscope
Ah okZRimaZ wrote: 18 Oct 2022, 06:47No, just copy/pasteoscilloscope wrote: 18 Oct 2022, 06:46No worries , I'll certainly do that. , does the microcontroller need a checksum performing in it if its a straight copy over?![]()
- 9100 Views
Last post by RickHaleParker
- 8963 Views
- 27 Replies
- 27980 Views
Last post by cn90
- 10412 Views
Last post by jonesg
- 5585 Views
