Vida CEM swapping
RickHaleParker
Been thanked: 958 times
Re: Vida CEM swapping
Post by RickHaleParker »
oscilloscope wrote: 25 Oct 2022, 14:56 Do you mean via an open source obdii reader where the k-line source code is freely available?
No ... You can build a cracker with a K-Line but it is only useful with the CEM-B through the OBDII connector. If you tap the CEM-B CAN on a port other the the OBDII port you do not need K-line. It not worth the extra effort to add K-line to a cracker. As VTL pointed out, you can tap the CAN-LS and CAN-HS at the REM instead of going through the OBDII connector. No K-Line required if you tap at REM.
The cracker code can talk to a CEM-B but it cannot crack a CEM-B.
oscilloscope
Year and Model: 2005
Has thanked: 27 times
Been thanked: 11 times
Post by oscilloscope »
Finally they have arrived
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
That's a lot of crackers! ;)
oscilloscope
vtl wrote: 27 Oct 2022, 07:54 That's a lot of crackers! ;)
The seller only sells them in sets of 10 so i purchased 20 . I figured if I mess up 1 or 2 I have some spare transceivers. , as there obsolete there might be a module I have or ecu that needs an emergency transceiver transplant. So figured also it might be useful. Oh and I'm abit of a horder.
oscilloscope
T5Luke wrote: 22 Oct 2022, 16:03 download/file.php?id=75855
It was here... Page 225
In regards to the dice obd dongle, does it need to be it ? or can I use any sort of J5234 obd dongle to work with the pieces of software?
oscilloscope
I had to buy 5 of the pcbs when I only want 1
LukeFlynn
Year and Model: XC70, S40
Post by LukeFlynn »
We have pretty much given up on cracking the old 99-04 CEMs right?
Even so, if I take a dump of my CEM is there a tool available to edit the config without using the paywall-filled VDASH stuff?
I'm aware of the Volvo tools, but do not have the necessary database files to use them
scaro
Year and Model: Volvo&Audi
Has thanked: 14 times
Post by scaro »
A couple of post back (many) you have T5Luke`s prog (thanks for this) if you dont want to change manually in file.
244 Turbo (86K miles) 1983
242 B230FK, Rollcage, LSD 1984
244 B21A with R-Sport Turbo-kit 1980
A5 2.0TFSI Quattro Conv. 2012
A4 1.9TDI 1997 BV43, 11mm vp37, 0.26 nozzels, 6speed, A8 brakes front, S4 discs/calibers rear
A4 1.9TDI 1998 Daily
oscilloscope
does anyone know a way too synchronize a Volvo xc90 with a ecu of edc1631 with eeprom 95320 + cem L with the eeprom of 93c86 on bench?
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
What way do you mean? There is commercial way for example... )
