98 V70 T5 Manual - Low boost on ARD Green Tune
Seaway
- Year and Model: 1998 V70 T5 Manual
Should I redo the CBV and make sure that it holds vaccum? When I insert the CBV diaphragm and spring, should the spring be compressed and in the "locked" position (held in compression by the plastic cap thingy)? I did not install it that way when I redid it the other night.
Seaway
Fixed. Put in a third cbv, swapped out the short hose between the ote pipe and the turbo, and put in a new hose from the cbv to the manifold. Boosted like it should and held like it should.
Also replaced the faulty ABS module while I was in there.
- Has thanked: 2209 times
That is great news! Must be so satisfying to get to the root of the issue with a little guidance and a lot of hard work and persistence on your part! Well done!
Seaway
Very much so. I wish I had gotten it right the first time, but I will take it. And I can swap out a cbv in 30 minutes now, so if you need tips, just ask.
So now I have done the following : new jewel headlights, new hoses throughout, new front and rear brakes, pads, rotors and calipers, rebuilt the turbo, led lights throughout, new O2 Sensors, new transmission mount, new torque mount, new AC blower, Snabb intake pipe, pcv system, R gauge cluster, R front bumper (to match the R motor and interior) and two sets of wheels and tires.
Guess I'll keep it!
Guess I'll keep it!
CBV and TBV, can anyone fill me in on what these stand for?
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
Seaway
CBV = Compressor Bypass Valve (round thing on the turbo that house the spring loaded diaphragm - hose leads from it to the intake manifold)mika wrote:CBV and TBV, can anyone fill me in on what these stand for?
TCV = Turbo Control Valve (also referred to as the boost control solenoid by some).
- Has thanked: 312 times
- Been thanked: 818 times
Seaway is not actually changing the CBV, he is removing the cover on the CBV, opening it up and switching the membrane in and out.
A torn CBV membrane is super common now to see on any of these old turbos, it is one of the first places to look when boost is limited.
TCV is mounted to the airbox.
- 2017 Views
Last post by bmdubya1198
- 1515 Views
Last post by matthew1
- 2213 Views
Last post by Grooveman221
- 11 Replies
- 3460 Views
Last post by MrAl
- 3122 Views
