Thanks.FireFox31 wrote: 10 Aug 2022, 17:56
Amazing results. How did you clean the calipers that well without a sandblasting cabinet? Granted, I'm used to seeing New England calipers "pulled from the lake", as people say. After getting my new four calipers stripped and powder coated, I intend to try and rehabilitate my current ones as spares, like you did.
I initially used electrolysis to help remove grime, previous coating (if any) and rust.
after being in there for an hour or so, I'd remove it, rinse it in clean water and scrub with a cheap metal brush (tooth brush sized.
After a while I realized that the electrolysis had done its de-rusting job and was now just laying down more black residue.
a little CLR (Calcium/LIme/Rust cleaner) seemed to remove a lot of the black residue. It could have just been elbow grease with the brush.
Then I chucked various sizes of wire wheels into a drill and that got most of the caliper back to bright shiny metal. I only had to clean up some nooks and crannies with the cheap wire brush by hand.
In fact, cleaning the calipers and bracket took most of the time on the job. Rebuilding the calipers and re-assembly was quick.
Also I know what you mean by the seal being tricky to get in the groove. The fact that the seal has many folds allows it to hide whether or not it is in the groove . I had to use a pick to pop it in the groove and then rotate piston to expose a fresh part that needed seating.
It was a satisfying project
