04 v70 steering line Topic is solved
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
new rack is bolted in now, working only at night to avoid the heat.
pressure and return lines are in.
Still need to connect the fluid lines to the rack and secure along the rack the best I can.
Trying to install the lower ujoint shaft on the rack but the shaft fell inside the footwell. duh
Need to get in the footwell and put the shaft on the rack but the car doors can't open when its on the lift, so I might have to climb through the window.
I might get it mostly done tonight.
jonesg
Post by jonesg »
Fat chance , after fighting with the rack connections I realized the pressure hose is the wrong design.
Pulled the pressure line out and compared old and new at the rack connection, very different bends.
This was a cheapo amazon $57 part I bought last November..., just placed an order from FCP.
Add another week.
jonesg
Post by jonesg »
New line arrtived, took hours but its in.
I removed the sway bar for better access.
Still need to connect the steering coupler but the major obstacle is done.
Has thanked: 1611 times
Been thanked: 4074 times
Those pressure lines at the rack are awful for access. When I did my 1999 I attached them and installed the rack with lines attached!
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
My 02 S60 required a crowsfoot socket…tight space!
08 C702.5T (sold)
The non-Swedes:
jonesg
Post by jonesg »
Krons wrote: 10 Jul 2026, 16:40 My 02 S60 required a crowsfoot socket…tight space!
did you not drop the sub frame ?,
I used a regular wrench on the pipe fittings, sub frame was dropped at least 8 inches.
jonesg
Post by jonesg »
abscate wrote: 09 Jul 2026, 23:42 Those pressure lines at the rack are awful for access. When I did my 1999 I attached them and installed the rack with lines attached!
The thought occured to me to thread the line then install the rack, at one point I pulled the rack and the pressure line out again and test fitted it on the bench, I feared it had gotten cross threaded but it was good, I made note of how the line has to be perfectly lined up along the rack, then I removed the threaded studs from the rack, it slid in place fast, like sh*t off a shovel.
Without the studs I could slide the rack around until the union lined up and it threaded in so much easier.
Studs went back in easy using the nuts to draw them back into place.
Krons
Post by Krons »
jonesg wrote: 10 Jul 2026, 21:44
No, on my 02 S60 FWD could just barely make it work with a crowsfoot — if I recall right I needed to use a 1/4” socket extension to be thin enough (with adapter on the crowsfoot). It was a super tight fit and partial rotation of the nut each time but could make it work. Not a fun job!!
08 C702.5T (sold)
The non-Swedes:
