Fuel Filter Replacement DIY
This topic is in the MVS Volvo Repair Database » Fuel Filter Replacement DIY
ac102nv
Year and Model: 99 V70 XC
Post by ac102nv »
I have no knowledge of the '98, but can't imagine it's much different.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Very nice write-up!
I just want to add a few tips/tricks. This can be done in 15-30 minutes.
Last time the fuel filter was changed at 60K (7 years ago), now at 120K.
At 60K, I applied anti-seize to the 12-mm bolt, it made it easier this time!
Anyway, this is the way I do it.
1. I use Bosch Fuel Filter, about $18-$20 online.
Do this job outside of the house!
2. Drive the RIGHT Front and Rear Tires on ramps. See pic.
I lay on a piece of cardboard.
3. De-pressurize the fuel as mentioned in other posts; either pull relay (while car running), or depress the Shrader valve at the fuel rail (with engine off, just remember to put the cap back on!).
4. Using a 15-mm wrench to counter-hold the square nut (this part was left out in the original thread!), loosen the 12-mm bolt. In my case I removed the bolt completely so I can lube it with grease (so it is easier to remove at the next time 60K from now).
5. Now, use the 15-mm wrench to disconnect the hose in front of filter, cap it so you don't lose fuel.
You can cap with a "finger" cut off from rubber glove + rubber band (see pic), or use the cap that comes with new filter to cap it.
Once you have the filter out of the car, it contains approx. 400-500 cc of fuel. You don't want to trash it!
So if you have a lawn mower, empty the fuel (via the front outlet) into the lawn mower gas tank.
6. The factory filter has a rubber band around it but I threw it out @ 60K miles.
- This time, I applied a few wraps of black electrical tapes so the clamp can "bite" nicely on it.
- Pay attention to direction of flow!!!
- I also apply a very very very thin smear of grease on the filter outlet (just make sure nothing gets in the hole), so it slides very nicely into the coupling. This may prevent any possible leak later.
7. Now you need to prime the fuel filter! You can either:
a. Jump the fuel relay connector but there is a much easier way.....
b. Turn the key to position II (do NOT crank the engine).
- Every time the key is turned to position II, the fuel pump is energized for about 4-5 seconds or so.
- Remove the key, then re-insert the key and turn to position II.
- Repeat this step about 8-10 times, the fuel filter should be full of fuel now.
8. Now start the engine. Check for any fuel leak.
That is all folks!
alexk243
Year and Model: 1993
Post by alexk243 »
Is there no hose clamps on it? Or no need for hose clamps on it? I have always had them on bikes fuel filter...
1993 Volvo 850 (w/97' engine in it)
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Nope, no hose clamps.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Are you guys changing your filter sooner than every 100,000?
Post by cn90 »
Well,
I just bought a 1998 S70 GLT with 145K miles, I can see that the fuel filter is still covered in black rubberized spray from factory!
It is way overdue and I will replace it soon!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2858 times
Been thanked: 1332 times
Post by matthew1 »
rspi wrote:Are you guys changing your filter sooner than every 100,000?
I'm averaging 60k.
CN, 145k! That filter's got to be thick with junk on the inside. Congrats on the new P80!
Also -> Amazon link
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
I changed mine well over 200K - way too long. The gas dripping out of the filter was very black.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
my volvo850
Year and Model: 1994 850
Post by my volvo850 »
Thanks, I can do that! I think the Marlboro ands a touch of class, long as there's no clinker!
Post by cn90 »
A quick note on the anatomy of the Fuel Connector (aka Quick Disconnect):
There have been many cases when people cannot remove the connector at Fuel Pump or Fuel Filter.
If one takes a look at the photo below, then it will make MUCH easier. I sketched a generic design of the Fuel Quick Disconnect. There are some variations of this design (GM, Jeep, BMW etc.), but the idea is the same. In the Volvo or Bosch Fuel System:
1. The metal pipe (at Fuel Pump, Fuel Filter etc.) is usually 8-mm in size.
2. The sealing effect is accomplished by squeezing the GREEN O-ring(s). There maybe one (1) or two (2) O-rings.
3. The Release Tab: if you push it toward the Connector, it will release the Red Tangs, allowing the metal pipe to pull out.
This is why if you use the Pickle Fork or 15-mm wrench to pry it, the tool basically presses the Release Tab toward the connector, allowing you to disconnect the fuel line.
Just make sure during install, the line is fully seated at the metal pipe!
So when you disconnect the line either at the Fuel Pump or Fuel Filter, as long as you have the right tool hooking UNDER the Release Tab, push it toward the connector to release.
This is all, no big secret!
