Add an Ipod Input to tape player of SC-815/816
This topic is in the MVS Volvo Repair Database » DIY: iPod/iPhone Input for SC-815/816 Radios
opeter
Year and Model: s60 2004
Post by opeter »
cn90 wrote:Yes Matthew,
That photo was incorrect.
I have put together a composite photo showing both the incorrect and correct method.
Again, no need to remove the cross bar or cassette player. Once the CD player is out, you can solder it using a fine-tip soldering gun...
Hi!
Does someone know if this is possible on the HU-603?
Im tired of the crappy adapter!
b2fkb0
Year and Model: V70r,855r,s70t5m,xc
Has thanked: 5 times
Been thanked: 4 times
Post by b2fkb0 »
Hey everyone,
Sorry I've been away from this post for a year! Matt, thanks for correcting the mistake I made; however, I must correct the correction! This is what the the wires should look like.
If you wire per my original or the correction above, you'll get one channel. This will get both. I had to get my original 816 that I did three years ago to find the correct pins again and I just got the second one (black faced) to work. Sorry for the confusion! My eyes aren't what they used to be; but if you look at the pic you can see Rch and Lch clearly over the feeds to these pins. Thanks everyone.
Dan
b2fkb0
Post by b2fkb0 »
xHeart wrote:Just to verify if the ground wire (green) fastened at the philips screw on the frame?
Daughter would love this.
Yes, green to the frame as in my pics.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
b2fkb0 wrote:...Matt, thanks for correcting the mistake I made; however, I must correct the correction!
I need to reply to the comment above "If you wire per my original or the correction above, you'll get one channel":
- If you wire according to the very first photo ---> 1 channel. So don't do that.
- If you wire according to method by me cn90, EstVolvo, or bags519, it will be fine.
- On the other hand, I understand that there are more than 1 way to do this, so you may want to try the newest photo by b2fkb0.
It is your choice.
Post by cn90 »
To avoid confusion, I borrowed a photo from another post and consolidate different methods in one photo:
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
CN90, thanks for making that image and writing the followup text above it.
I think this is as straightened out as it's going to get. I'll add these to the head post of this thread.
Also -> Amazon link
milesursogood
Year and Model: 850 T-5, 1997
Post by milesursogood »
kcodyjr wrote: Somewhere along the tape path, there will be a cam that detects the presence of tape under tension. If it doesn't get any, it assumes the tape is being eaten, and ejects it. Look for the cam and either simulate its being held under tension, or short its contact switch.
Has anyone figure out how to keep the tape from ejecting? The tape in my deck keeps on ejecting even when I press the "cassette" tape button or reverse the playback direction.
1997 850 T-5 142k miles - Mobil-1
milesursogood
I'm able to simulate the tape under tension by opening the tape & re-routing the tape inside the cassette. I have an SC-815 deck that doesn't have an Rch and Lch pass through hole on the PCB. I found this tip, http://www.atthetipwebs.com/technologyi ... eo_mod.htm, where I ended soldering the 3.5MM audio cable wires to the connections on the rear PCB (#10).
heinrich1899
Year and Model: dodge caravan 2002
Post by heinrich1899 »
Cool stuff here on this site!
Well, I did exactly as described, but I can't seem to get the cassette tape to stay in the stereo.
On top of that, I don't even know if it ever worked, because I never listened cassette tape's before.
Any idea as to why it won't accept the cassette tape?
I am totally lost now.
Thanks a lot!
Type2meister
Year and Model: 2000 v70se
Post by Type2meister »
I had the same problem but hit 'PROGRAM' and it's all good!
Thanks...this is great!
