Control Module replacement on 1997 850
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
Yes they are both the same and that's a good price for the Bosch part (and the right part), fine to jump on it. 137k it isn't even half way if you want to do the maintenance.
Connector is a good point, but that can be tough to diagnose. A junkyard MAF (i.e. a known good one) helps with that.
DavidB
Year and Model: 1997 850
Post by DavidB »
I did note that you mentioned the connector. What am I looking at for that? Do you mean the little electrical plug that I unplugged from the MAF or the physical tubing itself?
If it is the little electrical plug, what should I be looking for?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
About your edit:......N O ! ! ! :mrgreen:
About connector.....it's clipped and it can't be loosened or something like that.The problem is in wires which connects to pins....before the connector itself.
The only way is to secure the wiring towards down:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
DavidB
Post by DavidB »
the connector was not loose or anything, I didn't look at the pins for corrosion, bent, damage, etc, but I'll do that just in case, I can't imagine what else I can look at it for though... ?
